Fibaro dimmer 2 for 2 different lighting circuits possible?
I have a double light switch in my living room that has 2 switches, one for one part of the living room and the other for another part.
Can I use a single dimmer to control both of them independently or do I need 2 dimmer?
The Dimmer 2 only controls one light circuit. You could use the S2 switch to control another module on another light though.
@alitech
The Fibaro dimmer module can only control one circuit, you could rewire so both sets of living room lights are on the same circuit and hence would work with a single dimmer.
If you had the Fibaro dual relay module it can separately control on/off two lighting circuits.
To dim two separate circuits you will need two Fibaro dimmer modules.
