Hi, I’ve been struggling with finding a proper solutation for my problem so i thought i put it out here to see if anyone is up for the challenge
So,
In my living room, on one end of the long side i have 5 Led Downlights running on 5w and a driver connected to each lamp which has an input of 220v. (i live in sweden)
On the other long side of the living room i have exactly the same setup.
My problem is how can i have a different dimmer switch controlling each side of the living room.
I want 2 different Dimmer switch which i can control each wall.
But every single dimmer switch i can see is a single switch. So i can’t buy 2 and place them next to each other since inwall box is not big enough to install 2 dimmer boxes in one.
So i though ok why not go with a z-wave Touch dimmer which has to buttons which control and dimmers each wall. that should fit the inwall right? well, not that easy it seems. i can’t seem to find any touch dimmer supported by smartthings. which runs on a 220v.
So i thought alright well Fibaro dimmer 2 should fix all this. wrong again. If i install a fibaro dimmer 2 under a regular 2 dimmer switch. Sure i would be able to control the downligts separately on each wall, but how would the 2 dimmer switch and fibaro dimmer 2 be synced. For example if i dim down the lights to 50% with smartthings app, the dimmer wall switch won’t calibrate itself to 50%.
Hopefully some of you guys know any specific product or solution to this problem.
All help is better than nothing at this case!
