Of course, logcat is our goto when writing/debugging devices or drivers. Here are some suggestions to improve the tool.
- Improve messages when a Z-wave event received. A message stating “received event with handler unnamed” is confusing at best. Is there a way to name a handler so that the message is more meaningful?
2023-04-10T15:21:33.535205190+00:00 TRACE Z-Wave Leviton 4-Button Scene Test Received event with handler unnamed
2023-04-10T15:21:33.536173190+00:00 INFO Z-Wave Leviton 4-Button Scene Test <ZwaveDevice: 17ec5cb1-25a0-4923-8fa7-f5b6c95521d6 [4B] (Leviton 4 Button Switch)> received Z-Wave command: {args={dimming_duration="default", scene_id=2}, cmd_class="SCENE_ACTIVATION", cmd_id="SET", dst_channels={}, encap="NONE", payload="\x02\xFF", src_channel=0, version=1}
2023-04-10T15:21:33.588520523+00:00 TRACE Z-Wave Leviton 4-Button Scene Test Found ZwaveDispatcher handler in Z-Wave Leviton 4-Button Scene Controller
2023-04-10T15:21:33.589512857+00:00 TRACE Z-Wave Leviton 4-Button Scene Test ------ Received Scene_Activation
- Inaccurate statement about using default dispatchers. Frequently get the following when a driver is first deployed.
ZwaveDispatcher: Z-Wave Leviton 4-Button Scene Controller
default_handlers:
BASIC:
SET
REPORT
MANUFACTURER_PROPRIETARY:
0
MANUFACTURER_SPECIFIC:
GET
REPORT
SWITCH_BINARY:
REPORT
SWITCH_MULTILEVEL:
START_LEVEL_CHANGE
STOP_LEVEL_CHANGE
REPORT
SCENE_ACTIVATION:
SET
SCENE_ACTUATOR_CONF:
GET
REPORT
SCENE_CONTROLLER_CONF:
GET
REPORT
ASSOCIATION:
GROUPINGS_REPORT
REPORT
child_dispatchers:
when, in fact, I have overridden the default handlers in my code:
local driver_template = {
NAME = "Leviton VRCS4",
zwave_handlers = {
[cc.BASIC] = {
[Basic.SET] = basic_set_handler,
[Basic.REPORT] = basic_report_handler
[cc.SWITCH_BINARY] = {
[SwitchBinary.REPORT] = switch_binary_report_handler
[cc.ASSOCIATION] = {
-- [Association.Groupings_REPORT] = association_handler
[0x06] = association_groupings_report_handler,
[Association.REPORT] = association_report_handler
[cc.SCENE_CONTROLLER_CONF] = {
[SceneControllerConf.REPORT] = scene_controller_handler,
[SceneControllerConf.GET] = scene_controller_handler
[cc.SCENE_ACTUATOR_CONF] = {
[SceneActuatorConf.GET] = scene_actuator_conf_get_handler,
[SceneActuatorConf.REPORT] = scene_actuator_conf_report_handler
[cc.SCENE_ACTIVATION] = {
[SceneActivation.SET] = scene_activation_handler
[cc.SWITCH_MULTILEVEL] = {
[SwitchMultilevel.START_LEVEL_CHANGE] = switch_multilevel_start_handler,
[SwitchMultilevel.STOP_LEVEL_CHANGE] = switch_multilevel_stop_handler
[cc.MANUFACTURER_PROPRIETARY] = {
[0x00] = proprietary_handler
[cc.MANUFACTURER_SPECIFIC] = {
-- -- GET
[0x04] = proprietary_handler,
-- -- REPORT
[0x05] = proprietary_handler
supported_capabilities = {
capabilities.switch,
capabilities.switchLevel,
capabilities.refresh
capability_handlers = {
[capabilities.switch.ID] = {
[capabilities.switch.commands.on.NAME] = capability_handle_on,
[capabilities.switch.commands.off.NAME] = capability_handle_off,
[capabilities.switchLevel.ID] = {
[capabilities.switchLevel.commands.setLevel.NAME] = capability_switch_level_set
lifecycle_handlers = {
init = init_driver_handler,
added = device_added,
infoChanged = device_info_changed
can_handle = can_handle_LEVITON_VRCS4,
The default handlers take care of the Command Classes and the translation to capability events
for most devices, but you can still define custom handlers to override them.
defaults.register_for_default_handlers(driver_template, driver_template.supported_capabilities)
local buttonSwitch = ZwaveDriver("Z-Wave Leviton 4-Button Scene Controller", driver_template)
buttonSwitch:run()
It would be good if logging would state that default handlers have been overridden!
- And, of course, adding logging for the Rules API!
Henry
