fcc id b4z-680b-pir motion sensor is it compatible with ST?
No, it is not.
i am able to pair but not working what type do i need to select i have V3
How are you able to pair it? It is not a z-wave or zigbee device.
i removed the battery and sync it with ST it was detected by ST
Can you show a picture of the back of the device where the model number would be?
Yeah…won’t work with ST…just like all the other posts you’ve made in your last 4 days on the forum. MUTE.
thanks…can u advise if Sercomm door sensors work with ST?
