I noticed that my Good Night Routine did not complete last night. The logs showed that SHM was armed and that mode was changed, but in reality neither happened. I’ve replicated the routine this morning to see what happens in the live log and I’ve got this to share:
The routine didn’t change mode, didn’t set the alarm to away, didn’t lock the doors, didn’t change the thermostat. This may be the root of many routine failures that we have seen recently.
Update: the house behaves as in Night mode (light mode restrictions are taking place) however, bothe IDE and phone app are showing Daytime mode. Moreover, SHM is detecting intruder alerts, but doesn’t send any notifications, even though the live logging is stating otherwise.
True, but the difference is, that I made no changes to this routine and it used to work. So something has changed recently, that’s all I am pointing out…
I have located the offender! Wemo Connect…I was turning off 2 wemo switches and the routine was restricted from running if a Wemo switch was on. Once I removed those, the routine ran fine…@ErnieG running it manually for me was hit and miss…
I actually had the exact same things happen. My routine automatically published, the app said it was in the specified mode, when I entered the house my security alarm went off. I had to manually set it to initiate and then it worked. I submitted a ticket to support and they said it’s a KNOWN ISSUE and they are working on it right now. They’re going to push an update soon to fix it.
Just happened to me too again too. All of this started happening around the same time the update for multiple accounts was implemented. I created a new “I’m Back!” under another name and it fixed it. Until today. I may create another and see what happens.
bamarayne
11
Interesting… The rule that failed on me this morning also has a Wemo light switch that gets turned on.
