Exposing SmartThings Appliances to HomeKit
I am interested in exposing home appliances to HomeKit or HomeAssistant–>HK. These are all cloud connected Samsung appliances (washer/fridge/etc.). I am not aware of a local integration available.
I have looked at using the SmartThings/HomeAssistant add-on but that integration requires exposing HA to the internet with port forwarding or tunnels. Homebridge looks decent, but doesn’t seem to support appliances.
The only thing I can think of is to create a driver that allows you to create virtual HomeKit devices that run on the ST hub and then create automations to mirror the physical devices.
Any other options? That last one is a heavy lift just so I can create a washing machine automation :slight_smile:
My ideal scenario is for the ST hub to act as a bridge for the cloud connected appliances, but I am aware that this is not in the product roadmap.
Can you give more details?
If you can connect SmartThings to Google Home you could then use a Starling Hub to connect your devices to Homekit.
Starling Hub connects Google/Nest devices to Homekit and now all devices in Google Home as well, so I have all my SmartThings devices in Homekit via Google.
I am not sure what would be exposed by Google as a trigger to create your routine as I don’t have a Samsung washing machine.
Not quite… it does not appear to support appliances as they are not in the supported devices list in Starling.
post updated
:slight_smile:
Incorrect it now supports ALL devices in Google, as I should know as I own one!
The starling hub still requires you to hand those devices over to Google though, correct? So Google would get that data about the devices?
Better check if appliances are supported. I don’t see them in the list except for robot vacuums.
You connect SmartThings to Google in menu, voice assistant. The Starling Home Hub app for iOS then connects Google to Homekit.
You can contact Starling here to ask if it will work.
Another option could be Homey. I’ve used their SmartThings integration to control my Samsung TV. With a Homey Pro hub (or the cheaper, recently announced Pro mini) you should be able to expose those devices to HomeKit, but I haven’t tried that myself. The benefit over HA would be that it doesn’t require a subscription if you have their hub. You would have to trust Homey (i.e., LG) with your devices/data, though.
Samsung should make their all appliance be matter compatible so user can directly add them into apple HomeKit
Just to update this thread. Starling, which was mentioned earlier in this thread, is no longer available for purchase.
