I have 15 Samsung Power Outlets installed and working with my Samsung Hub. One my network I have added Philips Hue Bridge and learning about managing Lighting. Samsung Hub recognises the Hue Bridge and lights. However it would appear the Hue Bridge does not recognise the Samsung Power Outlets.
I have commenced using the Apple Home Kit and here the Hue Bridge Lights recognised and I have been unable to identify home kit identifies either the Samsung Hub and Outlets.
Has anyone made progress here please?
At the present time SmartThings brand devices are not compatible with HomeKit. They do not include the special HomeKit chip. When connected to the smartthings hub they can be used with echo or google home for voice control.
Any device which is compatible with HomeKit will have the Homekit seal on the box.
The IHome plug-in pocket socket can work with both SmartThings and HomeKit, as can the Lutron plug ins if you also have the Lutron SmartBridge, but I think those two are the only pocket sockets that do at this time.
https://support.smartthings.com/hc/en-us/articles/211523263-iHome-SmartPlug
https://support.smartthings.com/hc/en-us/articles/115000864766-How-to-connect-Lutron-Caséta-devices
As you noted, the Phillips hue bridge can work with both SmartThings and HomeKit. So can the Lutron SmartBridge.
The SmartThings brand pocket sockets cannot work with the hue bridge directly.
More discussion in the following thread:
Thank you, very helpful to me understanding what I can do now.
I am thinking how long before Philips start selling a Smart Plug that integrates with Apple Home kit?
Regards Casique
https://community.smartthings.com/users/jdroberts JDRoberts Helpful
April 26
Any device which is compatible with HomeKit will have the Home kit seal on the box.
https://www.apple.com/ios/home/accessories/ apple.com
https://www.apple.com/ios/home/accessories/ iOS - HomeKit Accessories
Over 50 brands worldwide offer products that are compatible with HomeKit and your Apple devices — with more and more on the way.
https://support.smartthings.com/hc/en-us/articles/211523263-iHome-SmartPlug support.smartthings.com
https://support.smartthings.com/hc/en-us/articles/211523263-iHome-SmartPlug iHome SmartPlug
The iHome SmartPlugs are Wi-Fi enabled plugs that allow you to control lamps, small appliances, electronics, and more! Automate your iHome SmartPlug to your preference with SmartThings. The iHome S…
https://support.smartthings.com/hc/en-us/articles/115000864766-How-to-connect-Lutron-Caséta-devices support.smartthings.com
https://support.smartthings.com/hc/en-us/articles/115000864766-How-to-connect-Lutron-Caséta-devices How to connect Lutron Caséta devices
This article will tell you how to connect the following Lutron Caséta devices with SmartThings: Lutron Caséta Plug-In Dimmer (PD-3PCL-WH) Lutron Caséta In-Wall Dimmer (PD-6WCL-WH) Lutron Caséta In…
