I’ve been trying to get Locstar Z-wave locks to work with SmartThings, and whist the basic unlock function works many other functions etc give errors. I’ve tried both the stand lock handler and several other peoples handlers but all give the same errors. In particular these two errors:
118e76d3-ca3a-455c-a053-c3c161518f8d 3:06:27 PM: debug "zw device: 02, command: 7105, payload: 06 06 00 FF 06 06 0E 00 63 03 00 01 00 00 00 00 00 00 00 00 " parsed to null
118e76d3-ca3a-455c-a053-c3c161518f8d 3:06:27 PM: warn Exception ‘java.lang.IndexOutOfBoundsException: toIndex = 21’ encountered parsing ‘cmd: 7105, payload: 06 06 00 FF 06 06 0E 00 63 03 00 01 00 00 00 00 00 00 00 00’
and
118e76d3-ca3a-455c-a053-c3c161518f8d 3:18:32 PM: warn Exception ‘java.lang.NullPointerException: Cannot invoke method parse() on null object’ encountered parsing 'cmd: 8007, payload: 02 40 10 01 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00’
118e76d3-ca3a-455c-a053-c3c161518f8d 3:18:32 PM: debug Entered parse with zw device: 02, command: 8007, payload: 02 40 10 01 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
In the case of the case of the first error above it occurs when using a code to open the lock and I can see the used code in the data, but I always get the Exception error on the data.
I’m new to SmartThings so any ideas/pointers would be very gratefully received
