Hi all.
I’ve recently installed Lock Manager for my Yale lock and it works pretty good. But I find if I try and change a pin code for an existing user it’s a bit glitchy.
Sometimes it says “error refreshing page” or that there was a problem processing the request, in red writing at the top of the application. I keep trying and it seems to eventually work.
Is this a known bug on android devices and is there anything I can do to make it work properly? or maybe I’ve not got the latest version and it’s been resolved.
Whenever you have a question about a community – created smart app you will get the fastest answer if you ask in the author’s thread for that smart app. The author will automatically be notified when there is a new post, and other people using the same code may also be able to help.
In this case, ask in the following topic (this is a clickable link)
Thanks for your replies. Just updated to v1.4 and still seems to be an issue. If I try and change an existing code I see a red band along top, error refreshing page. Then a green band suggesting the user has been updated.
If I open the user again the code is the same. I can force the code to change by editing the pin then clicking hello home phrase on (without changing the home phrase just clicking done) then saving.
I have a Samsung Galaxy 7 if that has any relevance? Thanks
