noticed this in my device history on the phone app
with the corresponding logs from the IDE
appears that it reports correctly when the Celsius temp is an integer and not a decimal.
I reported this finding as feedback to sonoff just today.
@mattschuett Did Sonoff ever resolve the C vs F temperature reporting issue?
When you manually operate any of the switches on the 3 gang Sonoff WiFi switch does the switch status in Smartthings update? Or is Smartthings unaware that any of the switches were operated.
On May 16, they did ask me for some pics or video so they could better understand the problem. I sent that over the next day.
On May 26th I received this response.
Hi
We double checked with our technicans, for the problem,it is based on the smarthings setting.
For our TH16,it can show no problem of the temperature and humidity, but from smarthings, it can not support well. We will forward the problem to our technical department, they will try to talk with the smarthings about the function in the future. Please kindly wait for the update.
Regards,
Frankie in SONOFF
I have not heard anything since
Send them a reminder. I find Sonoff are very good at replying and giving you what you need but not very good at following up without being prompted
Any news regarding sonoff ifan02/03/04 integration with SmartThings , without burning Tasmota ?
Its not only smartthings. Ifttt displays only celsius as an option. Seems like an issue with ewelink use of 3rd party APIs in general.
@eWeLinkapp, do you have plans to expose power monitoring in SmartThings for the S31?
Hello,
My zbminir2 works fine with smartthings, but I can’t configure the detach relay in the app…
Will the integration really create the possibility of using just one app or will we always have to (also) use the manufacturer’s apps to access all the options and capabilities?
Thanks in advance.
That question you will have to ask to the eWelink forum for the cloud linking, while in the case of Matter bridging will depend on them and the Matter protocol reached in that moment.
At the moment, yes we need both apps.
Thanks for your answer.
I would like to issue another question. I have the hub smartthings on the Samsung monitor and the zigbee dongle. Can I use that hub in ewelink app? If so, the problem will be solved… or not?
Not sure now if I answered correctly your first question. I understood from your post you had paired the ZBMINI switches to a Sonoff zigbee hub and were seeing them in Smartthings (“also” you said), through the cloud linked service, or possibly by Matter. Some Sonoff zigbee hubs (the Ultra for sure, dongle I don’t know) can act as a Matter bridge and everything on them is brought into Smartthings. The reverse is not possible. That I think answers your second question, although there is no guarantee that the detached capability could be controlled there. Again ask on the eWelink forum if it comes across in Matter, although I doubt it. I have a ‘similar’ device (S-Mate) that could not be controlled but since the recent Sonoff update I can now see it in ST.
Going back to the first question, if you were actually talking about having them paired directly to your ST hub, the capability depends on the driver. For this, again ask eWelink if they intend to produce an official Sonoff driver for the Smartthings platform, as they do for several devices.
I paired directly to ST hub. And works fine. But the option to detach relay is not available. If I didn’t need that due to smart bulbs that I want to control was not a problem.
I have the ST hub and a Tuya hub. Looks like I’ll need a third hub. Thank for your help!
