Smartthings app showing lights on when they are off
Small Device Viewer app also showing lights on when off
Getting fed up of all this inability to just do what it says on the tin , only got 11 devices so far and at least 1 or 2 are doing something wrong daily , have I wasted my hard earned cash
It seems it’s a long delay in the apps knowing what’s happening to my things , is it because the cloud is somewhere out near Neptune , how can I speed it up
2 x osram lightify bulbs one in same room as hub ( twitchy ) one in room next to hub ( most probs with this one)
1 x multi sensor furthest away seems to have settled down a bit since hub update ( can be flaky but it is the furthest away )
2 x samsung plugs in same room as hub (ok)
1 x xiaomi motion sensor in same room (ok)
4 x Arlo cameras + hub , external ( no problems so far )
How do I strengthen my mesh without spending £££££
bamarayne
9
I recommend a mesh rebuild of the zigbee mesh
Remove the batteries from your hub.
Unplug your hub.
Leave it that way for 20 to 30 minutes, at least 20.
Plug it back in and keep an eye on your system over the next couple of days.
I’ve been having the same issues as the OP for months now. I switched from the Smart Lighting app to CoRE and have had the same results. I’ve had a ticket in with support since somewhere around November. The latest firmware update is no different - same issues. I have no faith that ST will resolve the problems with their platform, since reading back in the history of the threads here makes it clear that this has been an ongoing problem from the beginning.
