Everspring SP103 switch capability groovy code - please help
Hi, i am writing a code for SP103 (a z-wave motion sensor). By now i have taken as example the z-wave reference code. On the datasheet of Everspring SP103 there is written that it’s possible to turn on/off the device, i am in trouble with this.
Here there is the actual code:
metadata {
        definition (name: "SP103 z-wave", author: "Ivan Airola") {
                //capability "Contact Sensor" TODO replace with tamper alert
                capability "Sensor"
                capability "Battery"
                capability "Switch"
        simulator {
                // These show up in the IDE simulator "messages" drop-down to test sending event messages to your device handler
                status "dimmer switch on at 70%" : zwave.switchMultilevelV1.switchMultilevelReport(value:70).incomingMessage()
                status "basic set on"                    : zwave.basicV1.basicSet(value:0xFF).incomingMessage()
                status "low battery alert"               : zwave.batteryV1.batteryReport(batteryLevel:0xFF).incomingMessage()
        tiles {
                standardTile("sensor", "device.sensor", width: 2, height: 2) {
			state("inactive", label:'inactive', icon:"st.unknown.zwave.sensor", backgroundColor:"#cccccc")
			state("active", label:'active', icon:"st.unknown.zwave.sensor", backgroundColor:"#00A0DC")
                valueTile("battery", "device.battery", decoration: "flat") {
                        state "battery", label:'${currentValue}% battery', unit:""
                standardTile("contact", "device.contact", width: 2, height: 2) {
			state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13"
			state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00A0DC"
                standardTile("switch", "device.switch", width: 2, height: 2,
                            canChangeIcon: true) {
                        state "on", label: '${name}', action: "off",
                              icon: "st.unknown.zwave.device", backgroundColor: "#79b821"
                        state "off", label: '${name}', action: "on",
                              icon: "st.unknown.zwave.device", backgroundColor: "#ffffff"
                main "sensor"
                details (["contact", "sensor", "battery", "switch"])
        def result = null
        def cmd = zwave.parse(description, [0x60: 3])
        if (cmd) {
                result = zwaveEvent(cmd)
                log.debug "Parsed ${cmd} to ${result.inspect()}"
        } else {
                log.debug "Non-parsed event: ${description}"
        result
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd)
        def result
        switch (cmd.sensorType) {
                //case 8:
                //        result = createEvent(name:"tamper", value: cmd.sensorValue ? "detected" : "okay")
                //        break
                case 0x0A:
                        result = createEvent(name:"contact", value: cmd.sensorValue ? "open" : "closed")
                        break
                case 0x0B:
                        result = createEvent(name:"tilt", value: cmd.sensorValue ? "detected" : "okay")
                        break
                case 0x0C:
                        result = createEvent(name:"motion", value: cmd.sensorValue ? "active" : "inactive")
                        break
                default:
                        result = createEvent(name:"sensor", value: cmd.sensorValue ? "active" : "inactive")
                        break
        result
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
        def map = [ name: "battery", unit: "%" ]
        if (cmd.batteryLevel == 0xFF) {  // Special value for low battery alert
                map.value = 1
                map.descriptionText = "${device.displayName} has a low battery"
                map.isStateChange = true
        } else {
                map.value = cmd.batteryLevel
        // Store time of last battery update so we don't ask every wakeup, see WakeUpNotification handler
        state.lastbatt = new Date().time
        createEvent(map)
// Battery powered devices can be configured to periodically wake up and check in. They send this
// command and stay awake long enough to receive commands, or until they get a WakeUpNoMoreInformation
// command that instructs them that there are no more commands to receive and they can stop listening
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd)
        def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
        // Only ask for battery if we haven't had a BatteryReport in a while
        if (!state.lastbatt || (new Date().time) - state.lastbatt > 24*60*60*1000) {
                result << response(zwave.batteryV1.batteryGet())
                result << response("delay 1200")  // leave time for device to respond to batteryGet
        result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
        result
def zwaveEvent(physicalgraph.zwave.commands.associationv2.AssociationReport cmd) {
        def result = []
        if (cmd.nodeId.any { it == zwaveHubNodeId }) {
                result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
        } else if (cmd.groupingIdentifier == 1) {
                // We're not associated properly to group 1, set association
                result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
                result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
        result
// ----------USEFUL FUNCTION------------------
// Devices that support the Security command class can send messages in an encrypted form;
// they arrive wrapped in a SecurityMessageEncapsulation command and must be unencapsulated
//def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
//        def encapsulatedCommand = cmd.encapsulatedCommand([0x98: 1, 0x20: 1]) // can specify command class versions here like in zwave.parse
//       if (encapsulatedCommand) {
//                return zwaveEvent(encapsulatedCommand)
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
//def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
//        def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1]) // can specify command class versions here like in zwave.parse
//        log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")
        createEvent(descriptionText: "${device.displayName}: ${cmd}")
// If you add the Polling capability to your device type, this command will be called approximately
// every 5 minutes to check the device's state
def poll() {
        zwave.basicV1.basicGet().format()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
//def configure() {
//        delayBetween([
//                // Note that configurationSet.size is 1, 2, or 4 and generally must match the size the device uses in its configurationReport
//                zwave.configurationV1.configurationSet(parameterNumber:1, size:2, scaledConfigurationValue:100).format(),
//                // Can use the zwaveHubNodeId variable to add the hub to the device's associations:
//                zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId).format(),
//                // Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub every 4 hours:
//                zwave.wakeUpV1.wakeUpIntervalSet(seconds:4 * 3600, nodeid:zwaveHubNodeId).format(),
def on() {
		 log.debug ("turning on\n")
        delayBetween([
                zwave.basicV1.basicSet(value: 1).format(),
        ], 5000)  // 5 second delay for dimmers that change gradually, can be left out for immediate switches
        		  // value: 0xFF
def off() {
	 log.debug ("turning off\n")
        delayBetween([
                zwave.basicV1.basicSet(value: 0).format(),
}				  // value: 0x00
I have defined the function “on()” and “off()” but when they are called nothing switch. What is it wrong?
Thanks,
Ivanhoe96
First, this device is a motion sensor, so its values should be active and inactive. If I heard things right, You have it defined as a contact sensor with values of open/closed.
More importantly, I believe you may have misunderstood a line in the data sheet that you linked to because it was obviously written by someone for whom English is not their first language.
The data sheet says:
This Motion Detector is controllable to our modules, such as On/Off Module AN135 and Lamp Module AD130.
That does not mean the sensor itself can be turned on and off.
Instead, it means that you should be able to set things up so that if the motion sensor detects motion, it will send a Z wave command to one of their other devices, such as an on/off switch or a lamp module, which means that you can set it up so that when the motion sensor detects motion, the lamp will turn on.
The on and off commands being discussed in the datasheet are the ones that are being transmitted to another device.
If you look at the official conformance statement for this device on the Z wave alliance website, you can see that it does not accept any switch commands. It’s just a sensor.
https://products.z-wavealliance.org/products/393
So I’m not sure exactly what you were trying to do with your code, but you’re going to have to find a different way to do it.
yes, i have misunderstood that line. Thank you very much!
