I bought three of these and they would not work out of the box I found code on the net to add as an app but can this not be used to add directly ST and what is the process to do that ?
I am new to ST but not new to automation. There was also code for the Aeon Smartstrip that I want to use later to control my UPS’s on my VMWare lab and NAS to power them off and on remotely
I did not write the code this is where I found it and he should get the credit. https://github.com/jialong/smartthings
* Everspring HSP02 Motion Sensor
metadata {
simulator {
// messages the device returns in response to commands it receives
status "motion (basic)" : "command: 2001, payload: FF"
status "no motion (basic)" : "command: 2001, payload: 00"
status "motion (binary)" : "command: 3003, payload: FF"
status "no motion (binary)" : "command: 3003, payload: 00"
for (int i = 0; i <= 100; i += 20) {
status "battery ${i}%": new physicalgraph.zwave.Zwave().batteryV1.batteryReport(
batteryLevel: i).incomingMessage()
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0"
state "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main(["motion"])
details(["motion", "battery", "configure"])
// Parse incoming device messages to generate events
def parse(String description)
// 0x30 0x86 0x72 0x85 0x71 0x84 0x80 0x70 0x20
// 0x30 sensor binary
// 0x86 version
// 0x72 manuf
// 0x85 association
// 0x71 alarm
// 0x84 wake up
// 0x80 battery
// 0x70 configuration
// 0x20 basic
def result = []
def cmd = zwave.parse(description, [0x80: 1, 0x30: 1, 0x84: 2, 0x70:1, 0x20:1, 0x85:2])
if (cmd) {
// if( cmd.CMD == "8407" ) { result << new physicalgraph.device.HubAction(zwave.wakeUpV2.wakeUpNoMoreInformation().format()) }
if ( cmd.CMD == "8407" ) {
result = zwaveEvent(cmd)
else {
result << createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result}"
return result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd)
def map = [:]
map.descriptionText = "${device.displayName} woke up"
map.isStateChange = false
def results = [createEvent(map)]
results << response(zwave.batteryV1.batteryGet())
results << response("delay 1200")
results << response(zwave.wakeUpV2.wakeUpNoMoreInformation())
results
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = "battery"
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = false
map
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
def map = [:]
map.value = cmd.sensorValue ? "active" : "inactive"
map.name = "motion"
if (map.value == "active") {
map.descriptionText = "$device.displayName detected motion"
else {
map.descriptionText = "$device.displayName motion has stopped"
map
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def map = [:]
map.value = cmd.value ? "active" : "inactive"
map.name = "motion"
else {
map
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug("Configuration report: Parameter number ${cmd.parameterNumber}, Configuration Value: ${cmd.configurationValue}")
log.debug "Catchall reached for cmd: ${cmd.toString()}}"
def configure() {
log.debug "Configuring device..."
def cmds = []
// sensitivity
cmds << zwave.configurationV1.configurationSet(parameterNumber: 3, configurationValue: [8]).format()
// re-trigger interval
cmds << zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, scaledConfigurationValue: 120).format()
// on-off duration
cmds << zwave.configurationV1.configurationSet(parameterNumber: 6, size: 1, scaledConfigurationValue: 120).format()
delayBetween(
cmds,
1000
def test() {
def cmds = []
cmds << zwave.configurationV1.configurationGet(parameterNumber: 6).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 3).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 4).format()
log.debug "Sending ${cmds.inspect()}"
delayBetween(cmds, 1000)
