Event List
When I use the url
https://graph.api.smartthings.com/api/hubs/#id# gets all the events regarding the Device only. But to get the HUB events what url should I use?
Not sure if this is still the case, but I have this in my notes from about 6 months ago
Hub EventsGet the last few (currently 10) events for a hub.
https://graph.api.smartthings.com/api/hubs/idHashString/events
Params
 all=<boolean>
 max=<number>
 source=<boolean>
Note: The response looks just like the account events endpoint response.
Here’s where I got this from. It was last updated in 2013 so it may be out of date
The event sources for that url is
"eventSource":“DEVICE”
I want the evenSource for HUB.
Try this
https://graph.api.smartthings.com/api/hubs/#ID#/events?source=hub
it’ll default to 10 max, you can also add &max=100
