Edge Shelly drivers for Gen1 and Gen2 Devices
Note this
This driver requires that a forwarding bridge server is running on the LAN. This bridge server can be obtained from this repository: GitHub - toddaustin07/edgebridge: Forwarding Bridge Server for SmartThings Edge drivers · GitHub
MQTT Broker is better solution
OAuth-In app is other solution
Here are @orangebucket instructions
If you can get OAuth working using Shelly’s script, you can you share the script with me.
