[EDGE] Local SmartThings driver for Twinkly lights
I’ve published Twinkly Edge, a community SmartThings Edge driver that controls Twinkly lights over your local network.
It supports on/off, brightness, color, refresh, and selection of saved custom movies and built-in effects. The Effect list updates to show the choices available on the light. Choices are numbered (Custom Effect 1, etc.), rather than labeled with movie names.
Install
  1. Join the Twinkly Edge channel and sign in with your Samsung account.
  2. Accept the invitation, enroll your SmartThings hub, then install Twinkly Edge under Available Drivers.
  3. In the SmartThings app, choose Add device → Scan nearby.
The hub and lights need to be on the same LAN. Discovery needs UDP broadcast on port 5555, and control needs access to TCP port 80.
The driver has been tested with a Twinkly TWKP200RGB running firmware 2.9.1, including commands sent through a SmartThings hub. Fresh pairing and app display on other installations and Twinkly models would benefit from community testing.
Source, issues, and contributions: GitHub repository · Report an issue · Submit a pull request.
