I have no idea what this is
Could you send logs with the CLI of when the child thermostat is created?
This is a tutorial on how to install the CLI and capture the logs
Did you af the Vindstyrka IKEA device @Mariano_Colmenarejo ?
The standard ST driver only includes temperature and humidity. It doesn’t include VOC and PM.
I think it uses specific IKEA clusters and I have no information.
From what i can see, other platforms are polling to obtain the info…
Hi, @Mariano_Colmenarejo,
I have been using this driver since Dec 2022
See my post:
((EDGE Driver-Mc): Zigbee Temp Sensor and Child Thermostat Mc, Zigbee Temp Sensor with Thermostat Mc - #269 by Mariano_Colmenarejo)
I deleted my thermostat device by mistake and now it is showing as ZigBee Thing, It is not picking up the driver (It is still installed).
When looking at the device info in my.smartthings.com, it is showing Manufacturer Stelpro but not the model number:
Zigbee thing MC is not giving me any info either.
Removed power, removed device, readded device, No luck
Smartthings HUB V3
Device Stelpro Thermostat SMT402AD
Hi @mario550
The device does not pair because the model is not visible.
Try resetting it and tying it near the hub, you can bring the hub closer with a network extender or a longer LAN cable.
The driver is zigbee Thermostat Mc
@Mariano_Colmenarejo Great work on the drivers, I have been using a few of them and the support is amazing
With the zigbee-temp-humidity-child-thermostat-edge, could I ask you to add an extra fingerprint for the Tuya Humidity and Temp sensor please?(the one with the display (TY0201))
Hi,
Added to this driver version
You do not perform a driver change from zigbee thing Mc
Uninstall device and reinstall it with this driver version
Name Zigbee Temp Sensor and Child Thermostat Mc
Version 2024-04-25T15:59:23.549003156
- id: "_TZ3000_bjawzodf/TY0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ3000_bjawzodf
model: TY0201
deviceProfileName: temp-humid-battery
Thanks, that worked a treat
Hi Mariano,
Thanks so much for your drivers - been able to add a lot of my devices directly now!
The only thing I can’t yet are my Hama Smart Radiator Thermostats. I was able to connect them via your Zigbee Thing Driver, but could you add their ID so they are recognized as radiator thermostats?
Thanks so much!
Manufacturer: _TZE200_h4cgnbzg Model: TS0601 FingerPrinted_EndPoint.Id: 0x01 App Version: 0x43 ZCL Version: 0x03 Network ID: 0x2860 Zigbee EUI: A4C1381353C69404 Device ID: 62fecb8f-4502-4c37-8ccf-b43dafdcff74 Server Cluster: Ep: 0x01={ 0004,0005,EF00,0000 } Client Clusters: Ep: 0x01={ 0019,000A } Signal Metrics: LQI: 202 .... RSSI: -62 dbm |
Hi @Chomp8777
This device uses tuya cluster EF00 and does not works with my driver.
It could works with this driver
mfr = “SONOFF”, model = “TRVZB”
With my driver the sonoff valve works, which is similar
Acabo de encontrar este increíble artículo en AliExpress. ¡Échale un vistazo!
12,69€ | SONOFF-válvula termostática TRVZB Zigbee, Control de radiador de Escena Inteligente a través de la aplicación EWeLink por voz, funciona con Alexa y Google Home
https://a.aliexpress.com/_EICNU4R
Thanks so much for the quick reply, indeed with the Tuya driver they work flawlessly without their separate hub now!
But yeah, the Sonoff ones would’ve been the better pick in the first place probably.
Hi,
If your capture is correct, this device is a TS0601 and it could use the EF00 cluster and does not work with standard zigbee drivers.
Maybe it could work with Tuya personal EF00 driver.
On the Namron website there is no documentation of the clusters it uses
It has nothing to do with other Namron thermostats, this seems a Tuya clone device
Thanks for the reply. OK, that’s odd. Do you know witch driver?
I have exactly the same problem as @mario550 except my Stelpro Thermostat is SMT402AD01.
I have extended my SmartThings hub V3 (via ethernet) so it is right beside my thermostat, but it is still pairing as a Zigbee Thing.
I do have the Zigbee Thermostat Mc installed. When I look at the device in mySmartThings.com the model is blank.
Any thoughts?
When the model is blank you probably need to delete the device and then repair it.
Hi,
Please try the same thing I recommended to @mario550.
Since he didn’t reply to say whether the problem was solved or not, we don’t know what the solution was.
Sorry for not answering, @Mariano_Colmenarejo I tried everything still not working. Even tried to contact stelpro support no help.
Still getting zigbee thing
Factory reset
Deleted the device
Breaker off
Remove edge driver
Re-added it
