I do not know if this at all is related to other problems concerning sudden temperature drops? It happens randomly with a number of sensors at different locations.
(Aqara temp/hum/press and Zigbee Temp Sensor and Child MC driver)
The drivers are simple transmitters of the temperature values they receive from the devices.
The only thing they do is divide the received value by 100 to convert it into Β°C with 2 decimal places.
If it is a repetitive value and from one model and manufacturer, it may be a malfunction.
If you want you can check with the cli logs what value the device is sending
Ha!! Yesβ¦I wasnβt thinking! Thanks!! Iβll await the update!!
I was thinking that maybe this driver change/βcorrectionβ - which I think you contemplate - may be extended to - 100Β°C and not 0Β°C only?
Hi Mariano!
Iβm an italian user and in Italy we use Vimar as Thermostat.
there are a lot of pepole that canβt find a way to use their thermostats, because nobody use Vimar out of Italy.
We ask for your help, please.
A thermostat is a more complex device than a switch or a temperature sensor.
It is not enough to add your fingerprints to an existing driver.
Need to know all its characteristics, modes used, if it is used for heat, cold or bothβ¦, it is necessary to know the manual and the cluster and attributes it uses to see if it is possible to add it or have to write a specific subdriver and the most It is important to do debugging tests, viewing logs with the CLI
If you are willing to provide the manual and send logs with the CLI to debug the driver, then I could try doing that
Dear Mariano, thank you.
i donβt know how it works, because iβve never used it: for use vimar devices in classic way you need a gateway. in my home i havenβt install it, because i work only with smartthings and zigbee protocol.
I donβt know if this can help, anyway this is the link of the product: Termostato rotella connesso IoT2M grigio - 02973
of course iβm willing to share with you the logs, but i have to know how
really thanks Mariano
Hi @S.F.B @jrichardw
I need the fingerprints of yours devices to make the driver modification
Hi @Sgamo
2 months ago the Vimar 02973 thermostat model was added to the Zigbee Thermostat stock driver.
The fingerprints that were added are model = βWheelThermostat_v1.0β different from yours, which are model = βThermostat_v1.0β, although your Vimar 02973 model in the manual you published is the same.
I have added your fingerprint to my Zigbee Thermostat Mc controller and try to see if it works
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Thermostat Mc
Version 2023-10-23T11:40:42.842927385
- id: "Vimar/02973-smart-wheel-thermostat"
deviceLabel: Vimar Smart Thermostat
manufacturer: Vimar
model: WheelThermostat_v1.0
deviceProfileName: thermostat-fanless-heating-no-fw
- id: "Vimar/02973-smart-wheel-thermostat-2"
manufacturer: Vimar
model: Thermostat_v1.0
How do I find that? I looked in the ST app and on the advanced web portal and I cannot find the fingerprint.
In the advance web app the Fingerprints are listed as the Mfg. Code and Model. He needs both.
Ah!!! Thank you!!!
@Mariano_Colmenarejo hereβs the info:
Manufacturer Code: LUMI
Model: lumi.weather
Merged to Zigbee Thermostat Mc driver the TEST version for NAMROM thermostat tested by you .
This is the new driver version.
You can perform an App driver change to this new driver version.
I will delete the TEST driver version from my channel, but you can use this driver version until you delete this TEST driver version from your Hub.
Version 2023-10-23T16:50:50.897846628
- id: "NAMRON AS/4512737"
deviceLabel: NAMRON Thermostat
manufacturer: NAMRON AS
model: 4512737
deviceProfileName: namrom-thermostat
Please, could you delete the posts with logs published in this thread, they are no longer necessary and the thread would be cleaner, Thank you
Thank you for bringing this thermostat to the community, it seems very complete and good underfloor heating thermostat
Dear Mariano.
Thank you, but after the reconnection of the device in my hub, i canβt see from the app the possibility to switch driver.
i try in the IDE and the error is: Error changing device driver to βZigbee Thermostat Mcβ. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.
Am i doing something wrong?
Thank you
Hi @Sgamo
Delete the zigbee thermostat Mc driver from your hub and reinstall it from my channel.
You have to delete the device with the app and add it again with the search nearby option.
It is not worth changing the driver, the device is not configured correctly
Mariano, IT WORKSSSSSSS!!!
Last problem and i swear, iβve done, and i will not forget to repay you in the correct way for your patience and work.
Iβve got 3 thermostats, iβm asking myself why the first one work and the other 2 no.
i have to give you the fingerprint of the others? arenβt they the same?
It could be different
can i post it?
Of course!
