(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
Hi
Another topic has a discussion about the same device
Maybe @fido knows more about driver.
Edit:
frients with - find all hubs that support the Zigbee smart home frients
Frient SmartThings Edge drivers:
frients with SmartThings Edge
Sorry was an error of copy and paste.
Fixed other with same error, thanks
 Name         Zigbee Multi Switch and Child Mc
 Version      2023-08-01T18:48:34.05343202
- id: "TS0013/_TYZB01_xiuox57i"
    deviceLabel: Three Switch
    manufacturer: _TYZB01_xiuox57i
    model: TS0013
    deviceProfileName: three-switch
  - id: "TS0003/_TYZB01_8gqspaab"
    deviceLabel: TS0003 Switch
    manufacturer: _TYZB01_8gqspaab
    model: TS0003
  - id: "TS0013/_TYZB01_Lrjzz1UV"
    manufacturer: _TYZB01_Lrjzz1UV
    model: TS0013
  - id: "TS0003/_TYZB01_b8cr31hp"
    manufacturer: _TYZB01_b8cr31hp
    model: TS0003
  - id: "TS0013/_TYZB01_gvackgwu"
    manufacturer: _TYZB01_gvackgwu
    model: TS0013
Frient heat detector works fine with @Mariano_Colmenarejo driver ( Zigbee Siren MC ) @Mayank_Gupta
Thanks @TapioX and @fido for your response.
Thank you so much!! Works perfectly!!
Hi
Is it possible to add to the switch the power that is connected to this particular switch so I could monitor the energy consumption in the SmartThings Energy section ?
Hi,
This application only shows devices that smartthings authorizes or samsung appliances
I don’t know if this will ever change
Hi Mariano.
Is Tuya room light switch possible?
Hi @bobpoole
Added to this driver version
 Version      2023-08-04T13:29:38.545630407
- id: "TS0002/_TZ3000_b9vanmes"
    deviceLabel: TS0002 Switch
    manufacturer: _TZ3000_b9vanmes
    model: TS0002
    deviceProfileName: two-switch
Could you please add fingerprint for below window open/door sensor model ?
Manufacturer Code - Sercomm Corp.
Model - SZ-DWS08N-CZ3
Driver Name - Zigbee Contact MC
Hi @Dev2023
 Name         Zigbee Contact Mc
 Version      2023-08-04T21:21:33.624140882
- id: "Sercomm Corp./SZ-DWS08N-CZ3"
    deviceLabel: Sercomm Open/Closed Sensor
    manufacturer: Sercomm Corp.
    model: SZ-DWS08N-CZ3
    deviceProfileName: contact-profile
Could you please add fingerprint for below 4-gang multi-switch model ?
Manufacturer Code - ? / Tuya / Scimagic-RC
Model - ZG-003-RF
Driver Name - Zigbee Multi-Switch MC
Note, the switch can be controlled with the Zigbee Switch driver from SmartThings but all 4 gangs switch at once, rather than individual control of the 4 contacts.
Thanks :pray:
Hi
Unfortunately, I still do not see the driver to choose from in the device panel LELLKI Smart Power Strip. I kept it updated by adding and removing the β€œZigbee Multi Switch and Child Mc” driver from the SmartThings Hub v3. Didn’t the typo ELLKI instead of LELLKI creep in there? Unless it doesn’t matter. The manufacturer is not eager to solve the problem.
Hi @arapalski
Sorry, fixed in this driver version
 Version      2023-08-05T22:23:24.897161115
- id: "LELLKI/JZ-ZB-005"
    deviceLabel: JZ-ZB-005 Switch
    manufacturer: LELLKI
    model: JZ-ZB-005
    deviceProfileName: five-outlet
Thank you @Mariano_Colmenarejo , it worked. Everything works great.
Hi @Mariano_Colmenarejo. Can you add this too?
It’s 3 button smart switch of Hejhome.
Product Detail (Hejhome Multi Switch)
Thank you.
Hi @jhjeong
 Version      2023-08-07T15:24:55.914486777
- id: "_TZ3000_pdevogdj/TS0003"
    manufacturer: _TZ3000_pdevogdj
    model: TS0003
Dear Mariano,
When you added this 3 gang switch it works really good.
I bought a 4 gang switch, hoping it will work too. Unfortunatelly it is not.
Could you please also add it ?
It looks like this:
Hi @Sebastian_M
Remember that multi-component TUYA devices need to be paired from scratch with the driver for it to be configured correctly. It does not work with changing the driver
 Version      2023-08-14T14:21:11.543516014
- id: "TS0004/_TZ3000_vit9k2nb"
    deviceLabel: TS0004 Switch
    manufacturer: _TZ3000_vit9k2nb
    model: TS0004
    deviceProfileName: four-switch
thx, it works perfectly!!!
