See this:
[EDGE UDPATE] 2022-08-23
TL;DR
The TS0207 leak sensor (and its similar devices shown below) is NOT RECOMMENDED under EDGE due to technical limitations. I was able to port the driver over to Edge and it will pair, but it will not report properly and will be marked OFFLINE often. Other sensors are better and you get what you pay for.
Signatures of these not recommended devices:
deviceLabel: Tuya TS0207 Water Leak Sensor
manufacturer: _TYZB01_sqmd19i1
model: TS0207
deviceLabel: Blitzwolf Leak Sensor
manufacturer: _TYZB01_o63ssaah
model: TS0207
Technical details of why they suck:
By default, the device checks in every ~250 minutes with a full battery report. This is not configurable or adjustable.
It does not do long-polling or checkins (the Poll Control cluster is not supporte…
I have two of these (Blitzwolf branded). Personally I don’t mind if they go offline as long as they wake up if water is detected. They do, actually. Still using DTH though…
