(EDGE Driver-Mc): Zigbee Light Multifunction Mc
Hi @JKnight
I have been doing some tests and for OSRAM bulbs it works fine, you can configure the time that Blink is doing, I guess it is also in others like LEDVANCE and some others.
In the others that I have, that are Tuya, it only blinks one time and stop.
I will see the way to implement it even if it does not work for all models
Thanks @Mariano_Colmenarejo,
I know the blink capability is not consistent across devices, which is likely why we don’t see it available by default… but it sure would be nice to take full advantage of my hardware again. I certainly appreciate anything you might be available to come up with and am happy to beta test if needed.
Keep up the phenomenal work!
Hi,
Do any of you have this bulb? I bought it three years ago and it worked fine in a V2 hub without the drivers.
Now I’m transferring everything to a V3 hub with the drivers installed (thanks @Mariano_Colmenarejo for your great work!) and unfortunately the hub recognises it as a dimmable/warm/cold white bulb. It’s a GLEDOPTO GU5 RGB CCT regulable Color Floodlight:
I am using the Zigbee Light Multifunction Mc driver (Ver. 2023-02-05T17:18:35.867848564).
Mariano, I’m embarrassed to ask you to add this to your driver - you have a lot of work to do anyway, but I guess I have no choice. I would be eternally grateful.
Hola @norberto_bcn
Please, Install zigbee Thing Mc in your hub and Change device to this driver, to see fingerprints and add to driver
A cambio, dile a Xavi que se deje los 3 puntos este fin de semana en Villareal! :wink:
Device Info
Manufacturer: GLEDOPTO
Model: GL-S-004Z
FingerPrinted_EndPoint.ld: OX0B
App Version: 0x01
ZCL Version: 0x01
Network ID: OX549E
Zigbee EUI: 00124B0021EF25A5
Device ID: 185c868d-5e0b-44bb-96a3-
fbe884c09ab6
Server Cluster:
Ep: OXOB=(
0000,0003,0004,0005,0006,0008,0300 )
Ep: OXOD=/1000)
Client Clusters:
Ep: OX0D=/1000)
@Mariano_Colmenarejo se lo digo! :smile::wink:
Hola @norberto_bcn
Added to this versions of drivers
I added model GL-S-005Z that is same model but with 120ΒΊ light angle
 Name         Zigbee Light Multifunction Mc
 Version      2023-02-08T15:17:08.320596617
- id: "Light/Gledopto"
    deviceLabel: Light Gledopto
    manufacturer: GLEDOPTO
    model: GL-S-004Z
    deviceProfileName: rgbw-level-colortemp-2700-6500
  - id: "GL-S-005Z/Gledopto"
    model: GL-S-005Z
Thanks a lot!!! Eres un crack!
@Mariano_Colmenarejo how to set the circadian to false via sharptools? Not sure you have any experience on the platform but basically setCircadian = 1 works fine to enable it but setCircadian = 0 doesn’t disable :expressionless: Any idea how to perform disable via Sharptools rules?
I’m trying to fix this so that I can disable circadian in case I want to adjust bulbs manually. Via smartthings it’s impossible without turning the bulbs on, which I don’t want to do.
Thanks for the assistance! :slight_smile:
Hi @pentti_4
In routines is Turn on is checked then click on it again and will be unchecked
Thanks but I can’t seem to make this work. If I deselect turn on it greys out done-button and also my selected settings are wiped.
In Android App works fine!!!
I would have thought it wanted a string.
I don’t have this driver installed, but from a brief look at the code in the Github repo it seems to be looking for the string β€˜Inactive’ or β€˜Active’. In fact, it’s explicitly looking for β€˜Inactive’ to set it as β€˜Inactive’ and if it receives anything else as the argument it’s setting it to 'Active.
@joshua_lyon thanks, this would make sense :slight_smile: Didn’t realize I could have checked this from the code of the driver!
Hi @pentti_4
You should put a report so that they fix in the IOs App the option to deactivate the turn on, off and change action
Super, the two different lidl lights i added works flawlessly with the driver.
Hi, is the YSRSAI YSR-MINI-01 supported by this driver?
(NEW VERSION) of the Edge Driver Zigbee Light Multifunction Mc
Zigbee Light Multifunction GROUPS driver is merged with Zigbee Light Multifunction Mc driver
After 10 days without reporting incidents and the tests that I have done also work well, all optional device control GROUPS functions are merged.
The update will be done automatically.
It is possible that to see the new capabilities it is necessary to clear the cache of the App.
Driver version:
 Version      2023-02-15T12:12:08.143531759
The GROUPS version has been removed from the channel. Users who are using the GROUPS version can continue using it and switch to the Mc version whenever they want.
All group control functions are optional, disabled by default and explained in this link
Hi @Mariano_Colmenarejo
I’d love to use this driver with the a few of my bulbs where I’m having trouble with the stock driver as of today. 2x different types. I’ve grabbed the info using your ZigBee thing driver (thanks)
Manufacturer: Aurora
Model: RGBGU10Bulb50AU
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x01
ZCL Version: 0x02
Network ID: 0x8969
Zigbee EUI: 000D6FFFFE5CC3FB
Device ID: fdc8f62e-85ec-4fOb-8b8f- 5a1077a3f6e1
Model: RGBBulb51AU
FingerPrinted_EndPoint. Id: 0x01
App Version: 0x01
ZCL Version: 0x02
Network ID: 0xDD5D
Zigbee EUI: 00158D00025ABDD2 Device ID: 56a22803-a985-4a1a-910e- lefef55e6fef
Please let me know if that’s not enough info (or too much!)
I have one other type of aurora bulb which I’m not having issues with but it might be good to add that one as well just in case:
Model: TWGU10Bulb50AU
App Version: 0x01
ZCL Version: 0x03
Network ID: 0x4147
Zigbee EUI: 000D6FFFFE1E20CA
Device ID: ed0296b0-4d13-4ee0-87d9- a4df248f614d
Hi @NHF
The first 2 are RGBW 2700k-6500k and the last?
Tunable white 2200k - 5000k
Many thanks
