It seems that the device has not been installed correctly, there are capabilities that have not been updated.
What device is it, manufacturer and model? seen on smartthings, web advanced users.
Uninstall and reinstall the device, it should work.
Do not make a driver change, this does not configure device
Did it and it works.
Thanks @Mariano_Colmenarejo
This is a new Moes presence sensor - it is not EF00. Great new device for smartthings users.
Just found this amazing item on AliExpress. Check it out!
US $23.64 67%OFF | MOES ZigBee Human Presence Sensor Detector Radar Wave Detection Sensor for Home Security Tuya Smart Human body Exists Sensor
https://a.aliexpress.com/_on6aOVk
Can you add support for this device?
(it got EF00 name because it got Wesleyβs driver by default).
Thank you.
Hi,
For device configuration settings to work, use the EF00 cluster.
According to opinions on other platforms, it saturates the Zigbee network with messages if it is not configured precisely.
Itβs just my opinion, the more different devices you use, the more different drivers you will need, if you are already at the high limit of memory usage of your hub, this will not help you at all.
Try to use devices of the same model that you already have, that work well and you will be able to optimize the use of the same driver for several devices.
Hello @Mariano_Colmenarejo
Could you please add drivers for this water leak sensor?
Device ID: 321debbd-79f8-4518-b1c6-edbad54ae1fd
Model: TS0207
Manufacturer code: _TZ3000_upgcbody
Network ID: 67D0
Itβs Onenuo water leak sensor, code on the box: 898ZT. It shows as Zigbee Thing, I tried your Aqara Water leak sensor drivers, but it canβt use those.
Hi @Pospitch
this device exist in Zigbee Moisture Sensor Mc driver
You must install this driver in your Hub
Uninstall device with App
Re-install device with App and this driver
You Do not perform a driver change from zigbee thing Mc
How about this?
Info
Manufacturer
_TZE200_s1xgth2u
Model
TS0601
Endpoint
0x01
Device ID
0x0051
Profile ID
0xC600
Network ID
0x0104
Server Clusters
Groups
0x0004
0x01
Scenes
0x0005
0x01
Basic
0x0000
0x01
TuyaEF00
0xEF00
0x01
Client Clusters
Time
0x000A
0x01
OTAUpgrade
0x0019
0x01
Datapoints
Value
1
215
Value
2
33
Value
4
100
Enum
9
0
Value
10
350
Value
11
0
Enum
14
0
Value
19
6
Sorry, This device use cluster EF00
I just bought a new Fantem multi-sensor like a previous one that already worked with your driver Zigbee Multi Sensor MC
Turns out that it is another fingerprint even thoug should be the same device
so please, can u add new fingerprint for Zibgee Multi sensor MC driver?
Hi @RCBURGOS11
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Sensor Mc
Version 2024-02-27T10:11:52.341425187
- id: "_TZ3210_wuhzzfqg/TS0202"
deviceLabel: Fantem 4 in 1 Multi Sensor
manufacturer: _TZ3210_wuhzzfqg
model: TS0202
deviceProfileName: temp-humid-motion-illumin
I have also added them to the zigbee Motion Sensor Mc driver, this way you can have all the motion sensors grouped, if you have others that use that driver.
This driver is also more complete and has temperature report custom setting and signal metrics capability.
Name Zigbee Motion Sensor Mc
Version 2024-02-27T10:17:50.659844398
- id: "_TZ3210_zmy9hjay/TS0202" #from multisensor driver
manufacturer: _TZ3210_zmy9hjay
model: TS0202
deviceProfileName: motion-temp-humidity-illumin-battery
- id: "_TZ3210_wuhzzfqg/TS0202" #from multisensor driver
model: TS0202
Thank you so much!
as a update for the two devices Fantem 4 in 1 Multi Sensor:
both are working fine with the first driver mencioned βZigbee Multi Sensor MCβ besides more simple settings and optionsβ¦
just tried the more complex one βZigbee Motion Sensor MCβ as you described but in this case the temperature measurement is not getting update no matter what i doβ¦
Hello, I purchased these contact sensors through Aliexpress, could you help me with the controller?
I already installed contact mc but it does not detect it, I installed and uninstalled it several times
Hello @Luis_Aguilar
You must install this driver version in your Hub
Name Zigbee Contact Mc
Version 2024-03-05T12:21:08.806868653
- id: "_TZ3000_rcuyhwe3/Close Sensor"
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_rcuyhwe3
model: TS0203
deviceProfileName: contact-battery-profile
I have issue with all my Bosch ISW-ZPR1-WP13 and Visonic MCT-340 E Door Window Sensor, which are using Zigbee Motion Sensor Mc 2024-03-08T10:18:45.382913519 and Zigbee Contact Mc 2024-03-05T12:21:08.806868653, respectively.
Bosch ISW-ZPR1-WP13 says βWaiting Zigbee messageβ
While for Visonic MCT-340 E Door Window Sensor, they are all offline.
Iβm using SmartThings hub v2 000.051.00002, could it be any recently update break the drivers?
The last updates have only been to add some new devices.
It should not have affected the operation of other devices.
On some occasions, driver updates have caused some user some problems during the installation, due to memory, number of drivers, I donβt know the cause.
Sometimes the zigbee mesh breaks because a repeater changes location or is removed and affects other devices.
Maybe a reboot or shutdown of the hub, removing the battery from the v2, will fix it or not.
Maybe reinstalling the driver.
These Bosh devices are complicated to pair, they have a procedure that has given users many problems to pair them correctly, carefully consult the manual or perhaps in the thread there are tricks that other users have published.
I have this device
Would you happen to have this added into your amazing drivers?
