(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Excuse me Mariano,
Model is: IH-K009
Gracias!!
@Mariano_Colmenarejo I have following Tuya, ZigBee, Smoke detector connected to ST using your ZigBee smoke/CO mc driver.
Smoke and battery are exposed and work as expected. When connected to a Tuya Hub, Tamper is also exposed and works.
Would it be possible for you to add Tamper to the Profile for this detector.
Hi, how can I make my Sonoff Zigbee Mini work with a button connected (pulse mode)? There is no this option in the settings
With Tuya ZigBee smart relays you need to make the changes in the Tuya app (with Tuya hub) before pairing it with SmartThings. Then disconnect the device from Tuya and pair it SmartThings. The settings changes made in the Tuya app carry over into SmartThings.
I was referring to the model in the fingerprints.
Perform a refresh on zigbee thing, see if it shows it or it may not have a defined model
Hola Mariano,
I have refreshed some times but it persist with the same info, I think this one hasn’t a defined model.
Gracias de nuevo.
This device already existed as model TY0201.
I have also added it only with the manufacturer.
Remember that you have to uninstall it and pair it again with this version of the driver for it to be configured
Saludos
 Name         Zigbee Temp Sensor and Child Thermostat Mc
 Version      2024-02-15T20:53:09.131369026
- id: "_TZ3000_zl1kmjqx"
    deviceLabel: Tuya Temp Sensor
    manufacturer: _TZ3000_zl1kmjqx
    # model: TY0201
    deviceProfileName: temp-humid-battery
Hi Paul,
I have been looking in the Tuya documentation to see how it handles the tamper information, I have only found for contact and motion sensors, it seems that it uses a standard attribute.
The problem is that since smartthings does not have a default handler for tamper, it forces me to handle the smoke events manually in the driver, since it uses the same attribute as tamper.
I don’t know how important this is to you.
Not a problem. I can live without it. I was hoping it was just a simple profile change.
Thanks for looking.
Working perfect. Thank you Mariano. :+1:
Hi @Mariano_Colmenarejo,
Maybe you can help me solve this problem.
Using your driver for a bunch of devices - thank you!
When I connect new device the hub finds it but shows as β€œconnected” and I can’t control it. Sometimes it’s start to work by itself and sometimes I need to reconnect the device a few times…
Please see attachment.
Is there something I can check or do? Can I check the zigbee communication or something?
Thank you!
Hi,
Nothing has changed in the drive for more than 8 days.
If it doesn’t work well it may have to do with smartthings, the hub or your zigbee network.
You can try to reboot the hub
Thank you very much for the driver for the Sunricher /Namron Multisensor! I’ve had two of them in operation at two locations for a few weeks now and the temp, illum and movement - readings work flawlessly. The moisture - readings seems out of sync however compared to other readings in the ST environment as well those from Verisure, about 10 to 12 %-points. The attached are some typical readings from 2 ST (the Multisensor and an Aqara) and 1 Verisure sensor a few cm apart. I’ve tried to consult the driver code on github and the Sunricher documentation without finding any obvious cause for the discrepancy in the readings. Is it just a peculiarity of the multisensor?
(Btw: The driver does not expose any moisture offset opportunity. No big deal at all thoughπŸ˜€)
Hi @S.F.B
Added preference for humidity offset in this driver version.
I hope the profile is updated correctly with the new driver version, lately changes to profiles are not updated as quickly as before.
I don’t know what has changed, but sometimes you have to clear the app’s cache and sometimes not even with that. Luck!
 Name         Zigbee Motion Sensor Mc
 Version      2024-02-16T17:48:57.550208456
All well. A driver change was all to it. Thanks a lot!
I seem to have the same β€˜model’ TS0205, but the device only comes up with your identification driver ak Zigbee thing. Could I bother you to take a look what might be the issue/if this is missing from the list?
Smartlife/Tuya YG400A ZigBee Smart Smoke Detector
Product: https://nl.aliexpress.com/item/1005005854203557.html
Thank you!
Hi @zluts
This device exist in the driver Zigbee Smoke/CO Detector Mc
Install this driver in your hub and uninstall device and reinstall it
@Mariano_Colmenarejo hi
I’m using your β€œzigbee switch power mc” and can’t get it to show power usage.
(Trying to have it to shut down if a device is left on and forgotten)
Hi @eli_doron
Sorry, I don’t quite understand what your problem is exactly.
Thanks for the quick reply
I can turn the power on and off
But can’t get the power read.
It stays on 0 when using an electric device in that socket
