(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Hi!
I just got a “Cleverio” water leak sensor (“Water Sensor SS400” on the packaging), which pops up as a Zigbee Thing model: TS0207.
I was hoping that the moisture sensor driver for TS0207 would work, but it only shows the device information and no sensor data.
Is there something I should/could do on my end to get it to work or does it require a unique driver?
Best Regards
Hi @Foppemoa
Added to this driver version
  • You need uninstall your device
  • Install this driver version in your Hub from my channel
  • Add device with app to pair with this driver near of your Hub to perform correct configure device
Do not perform a driver change to this driver from zigbee thing Mc
 Name         Zigbee Moisture Sensor Mc
 Version      2023-11-28T20:59:57.501002429
- id: " _TYZB01_0eaduw43/TS0207"
    deviceLabel: TS0207 Water Sensor
    manufacturer:  _TYZB01_0eaduw43
    model: TS0207
    deviceProfileName: moisture-battery
Awesome, now it works.
Thanks a lot!
Is there a driver for the below? The native driver does not show battery and report lux level almost every few seconds.
Hi,
Added to this driver version, try it
 Name         Zigbee Motion Sensor Mc
 Version      2023-11-30T21:26:35.623905663
- id: "LUMI/lumi.sen_ill.mgl01"
    deviceLabel: LUMI Light Sensor
    manufacturer: LUMI
    model: lumi.sen_ill.mgl01
    deviceProfileName: lumi-illuminance
Works well, thank you again!
Thanks Mariano!
Is there any chance to expose support for setting the color ring values of the Fibaro Walli Outlet (Z-wave power outlet/switch), such that Parameter 11 - LED frame – colour when ON can be controlled by a SmartThings routine on the fly as a Command? This parameter defines the LED colour when the device is ON.
In other words, being able to run a routine and change the ring’s color based on e.g. an unrelated SmartThings event.
You can find out more on the device’s configuration on page 20.
Hi @cmanviva
What fingerprints does this device have to locate its code and profile within the driver.
I see some fibaro device profiles, but the LED color values in preferences do not match the values in the documentation posted.
These parameter values are normally in preferences and in order to use them in routines it is necessary to create a custom capability, a specific profile that contains this capability and a new subdriver to manage the code, which should only affect this model.
It’s a lot of work and I don’t know how important it is for you to use these LED color changes in routines.
Thanks for the info and quick response Mariano! Much appreciated. I understand that this is complicated. I wanted to use the LED indicator as a presence indicator for the room outside which it sits (and it would be triggered by a motion sensor inside).
I’ll find some other way, sounds too complicated to do. Thanks again!
Hi Mariano. Can you add the following Zigbee Siren that works with USB/Battery + lights
manufacturer: _TZE204_t1blo2bj
model: TS0601
Hi,
sorry, this device uses the EF00 cluster and does not work with my driver
Hi Mariano,
Hope you are well…I have a couple of these roller blinds motor that I had purchased and installed and they worked well till ST changed their platform… below if the link to the product…
Attached is the fingerprints. Could you please ad always create the driver for me for this product.
Do let me know if you need any other details.
Thanks in advance.
Lanio Carvalho
Hi @laniocarvalho
I am well, thanks. I hope you are well too
This device works with @iquix driver in this channel
https://account.smartthings.com/?redirect=https%3A%2F%2Fbestow-regional.api.smartthings.com%2Finvite%2FqWjB0pNyY62y%3F
Hi Mariano,
Many thanks! It worked!
Ad usual, your a star!
Wish you and your family happy holidays!
Regards
Lanio
Hi @Mariano_Colmenarejo
Can you please create the driver for this device?
Manufacturer: _TZ3000_wbfgbpxq
Model: TS0044
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x43
ZCL Version: 0x03
Network ID: 0xFEB6
Zigbee EUI: A4C1385F7F675011
Device ID: e868e50c-d425-4d43-b0a0-10f64445220e
Server Cluster:
Ep: 0x02={ 0006,0001,0006 }
Ep: 0x01={ 0001,0006,E000,0000 }
Ep: 0x04={ 0006,0001,0006 }
Ep: 0x03={ 0006,0001,0006 }
Client Clusters:
Ep: 0x01={ 0019,000A }
Signal Metrics:
LQI: 144 … RSSI: -62 dbm
It’s a remote control with 4 switchs, each one with single, double and long press function.
Thank you!
Sorry I’ll raise the request on the correct catalog.
Mariano,
Is it possible to add the driver for this TS0201 device?
_TZ3000_qaaysllp
Tuya IOT output:
"model": "",
"name": "Temperature Humidity Sensor 4",
"product_id": "qaaysllp",
"product_name": "Zigbee温湿度 NEO",
Sorry, I don’t have any driver for zigbee multi-button.
Hi @spacesloth
Added to this driver version with option of create a child thermostat device
 Name         Zigbee Temp Sensor and Child Thermostat Mc
 Version      2023-12-14T21:15:23.397013458
- id: "_TZ3000_qaaysllp/TS0201"
    deviceLabel: Tuya TS0201
    manufacturer: _TZ3000_qaaysllp
    model: TS0201
    deviceProfileName: temp-humid-battery
Added to this driver version as thermostat device profile
 Name         Zigbee Temp Sensor with Thermostat Mc
 Version      2023-12-14T21:16:14.580878698
    model: TS0201
    deviceProfileName: temp-humid-therm-battery-05
Thank you! Not sure if it matters, but this device also has a illuminance sensor (lux).
If you send me the information about which clusters the device supports I can see if I can add it.
Install and change to zigbee thing Mc driver and publish the information
