Here you go.
Manufacturer: _TZ3000_bnai1qnw
Model: TS0203
FingerPrinted_EndPoint.Id: 0x01
App Version: Unknown
ZCL Version: Unknown
Network ID: 0xFD59
Zigbee EUI: A4C13881BCAF407B
Device ID: e03388d8-ee0c-4066-8263-0f3e987fab9a
Server Cluster:
Ep: 0x01={ 0001,0003,0500,0000 }
Client Clusters:
Ep: 0x01={ 0003,0004,0005,0006,0008,1000,0019,
000A }
Signal Metrics:
Hi @dillans147
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Contact Mc
Version 2023-11-16T10:51:12.229277495
- id: "_TZ3000_bnai1qnw/TS0203"
deviceLabel: Samotech SM300Z Contact Sensor
manufacturer: _TZ3000_bnai1qnw
model: TS0203
deviceProfileName: contact-battery-profile
perfect thanks.
I have 2 natural gas sensors as seen here: https://www.aliexpress.us/item/2251832654305415.html?gatewayAdapt=glo2usa4itemAdapt could anyone please help with an edge driver?
Hi, do anyone know if any of these edge driver here works for Aqara Smoke Sensor JY-GZ-01AQ?
Pair your device with zigbee thing Mc and publish the fingerprint information and clusters it uses. With that information I could see if it can work with a standard driver.
@Mariano_Colmenarejo thanks.
See below
This device exist in the driver Zigbee Smoke/CO Detector Mc since one year ago
# added after 15 oct
- id: "LUMI/smoke.acn03"
deviceLabel: LUMI Smoke.acn03
manufacturer: LUMI
model: lumi.sensor_smoke.acn03
deviceProfileName: smoke-battery
Hi @Mariano_Colmenarejo . Do you happen to know if the tuya devices offline issue has any workaround? I am trying to find recent discussions about it. but, in the meantime I thought of asking if you happen to know of it.
Specifically TS0207 water leak sensors report offline after few hours of inactivity because of hardware limitations from what I understand. ([EDGE] Tuya Leak Sensor TS0207 ** NOT RECOMMENDED **)
So, just curious if there was any hack to fix this instead.
Hi @blitz79
There are no tricks that solve these problems.
Other times I have recommended this to other users
@Mariano_Colmenarejo thanks. Let me add the driver and test tonight. Appreciated
I have the following Tuya motion sensor working with your driver βZigBee Motion Sensor Mcβ
The motion works as expected, but battery level never shows. I have deleted and repaired it several times sitting on top of my hub. It always picks up your driver. It has been over 24 hrs.
Hi Paul,
Can you send me a log of the pairing to see if it accepts configuration correctly?
Use the default battery settings and it should work and send value every 6 hours
I will send you pairing logs in a couple days. Tomorrow (Thursday) is US Thanksgiving Day.
Hi @JayN
You need to delete device and pair with this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Temp Sensor and Child Thermostat Mc
Version 2023-11-25T16:41:00.766461358
- id: "_TZ3000_zl1kmjqx/TY0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ3000_zl1kmjqx
model: TY0201
deviceProfileName: temp-humid-battery
Added to this driver version too
Name Zigbee Temp Sensor with Thermostat Mc
Version 2023-11-25T16:45:07.506945079
model: TY0201
deviceProfileName: temp-humid-therm-battery-05
Mariano,
I brought the Tuya motion sensor home from camp, so I could capture the logs. I paired it at home and ran the logs. About 24 hrs. later the battery readings appeared, so there does not appear to be a problem. The following are the logs for dc415d65-49c9-42de-a3b7-b4befea93f60: They also contain other information since I use that driver for many devises.
Hi Paul,
The device has responded correctly to the battery reporting setting, which is 6 hours or 1% changes
IASZone has also been configured correctly, so it should work fine.
In this driver, the IASZone report interval is customizable from 300 sec, which is the default interval, up to 3600 sec.
If you have many devices and want to reduce Zigbee message traffic, you can increase that interval.
And I have it at 3600 sec and it works very well.
For the device to accept the change you must wake it up with an event just when you change the value in preferences.
You can see with the CLI if it has accepted the change by looking for this response one or 2 seconds after changing the value.
2023-11-23T04:44:57.712399728+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: dc415d65-49c9-42de-a3b7-b4befea93f60 [0x12F3] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x12F3, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFD, rssi: -41, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0B, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0002 > > > >
