(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Hi @aPsk
Added to this driver version
 Name         Zigbee Range Extender Mc
 Version      2023-10-06T21:54:21.209808678
- id: "_TZ3000_nlsszmzl/TS0207"
    deviceLabel: TS0207 Repeater/Extender
    manufacturer: _TZ3000_nlsszmzl
    model: TS0207
    deviceProfileName: range-extender
Hi,
Possible to add Tuya smoke detector :slight_smile:
Hi @Teemu_Huttunen
Sorry, this device uses tuya cluster EF00.
Try with personal EF00 cluster driver
Thanks!! Got them working :slight_smile:
Hi @Mariano_Colmenarejo
Since last update in zigbee-multi-switch-v4.5-childs-edge (7/10/203) my switchs automatically turn off and on after two minutes.
How can I help you troubleshooting this issue?
Thanks you.
Hi,
Exactly, what devices does this happen to?
Both switchs. Happens if switch 1 is on, if switch 2 is on or if both are on.
I am referring to the fingerprint, to know what I have to look for
Ups, sorry!
Its the TS0012/_TZ3000_fvh3pjaz
Hi,
I don’t know why it happened, but try this new version of the driver.
You may need to pair it again
Name Zigbee Multi Switch and Child Mc
Version 2023-10-16T19:49:27.462976563
Its solved after getting the new driver version and re-pairing. Thanks you so much!
Would it be possible to add the Third Reality Door/Contact Sensor? Model Number 3RDS17BZ
Amazon Link
 Name         Zigbee Contact Mc
 Version      2023-10-19T16:07:50.374519916
- id: "Third Reality/3RDS17BZ"
    deviceLabel: Third Reality Contact Sensor
    manufacturer: Third Reality, Inc
    model: 3RDS17BZ
    deviceProfileName: contact-battery-profile
Hi Mariano,
Is it possible to use this with your driver?
[Just found this amazing item on AliExpress. Check it out! US $15.32 25%OFF | ZIGBEE WIFI Garden Watering Timer Smart Sprinkler Drip Irrigation System Built-in Water Flow Recorder Water Controller TUYA https://a.aliexpress.com/_oBMdvVX](Just found this amazing item on AliExpress. Check it out! US $15.32 25%OFF | ZIGBEE WIFI Garden Watering Timer Smart Sprinkler Drip Irrigation System Built-in Water Flow Recorder Water Controller TUYA https://a.aliexpress.com/_oBMdvVX)
Thanks.
Hi @gmanor77
This devic use Tuya cluster EF00 and does not work with standard drivers
Thank you much appreciated
Hello Mariano,
Any chance to add MOES temperature and humidity sensor:
Manufacturer Code:
TUYATEC-gqhxixyk
Model:
RH3052
It’s a nice smalle sensor available for GBP6 from Aliexpress
Hi @daedalusminos
I make a note to add it when I have access to the cli
Hi,
 Name         Zigbee Temp Sensor and Child Thermostat Mc
 Version      2023-10-23T10:17:04.019818027
- id: "TUYATEC-gqhxixyk/RH3052"
    deviceLabel: Moes RH3052
    manufacturer: TUYATEC-gqhxixyk
    model: RH3052
    deviceProfileName: temp-humid-battery
Added ti this driver too
 Name         Zigbee Temp Sensor with Thermostat Mc
 Version      2023-10-23T10:19:32.530970085
Many thanks, I will test in 2 weeks when I return from vacation.
