Sorry, This device use Tuya cluster EF00 and not works with my drivers
Hi @bega00
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2022-12-09T22:14:35.021848068
- id: "TS0012/_TZ3000_jl7qyupf"
deviceLabel: Two Switch
manufacturer: _TZ3000_jl7qyupf
model: TS0012
deviceProfileName: two-switch
I close for today!
Hey @Mariano_Colmenarejo , could you add this device to the appropriate driver. It is a treat life 3 button scene controller
Sorry,
After restart of my mobile. All OK⦠Text display correct in Dashboard and details.
A quick change will be to display the the date and time for the latest measure in details⦠again if possible
Hi @troy_owens
I think this device works with @ygerlovin driver.
In mine driver does not works
Hi @dotan_shai
If I added the date does not fit in the dashboard and it would look bad.
I would have to put a new independent capability and it is not worth it, it is updated every 5 minutes, since smartthings put a 5-minute timer to read a device attribute so that it is not marked as Offline.
When you need to analyze the stability of the signal, select in preferences that the events are shown in the history and you will be able to see the evolution with date and time
here have create a drivers for moes 3gang wall switch that use EF00 cluster
i do not know how easy to add yours or must have it as device to test it etc..
give a try⦠also you @dorbenisti
Before anything else, great work with this drivers ![]()
I have a Aeotec Smart Switch 7. Before migrating to edge drivers it appeared with a Outlet icon, but now only appears the switch icon. Canβt that be changed?
Hi @DewDrop
I assume that you use the stock driver, it has the Switch category assigned to the profile and the App optional icons for that category do not include the plug icon.
It is incomprehensible that smartthings do not merge all the App optional icons of the Switch, SmartPlug and Light categories. This would give more flexibility to users and drivers could use a single profile instead of three or more different ones.
If you use the stock driver we can tag @nayelyz to see what they can do
Thank you
All working now.
Yiannis
I have already use @ygerlovin driver and it works, but without childs.
I want to have separate components for the lights and to able to rename them from βswitch 1,2,3β to convinient names.
Hopefully sometime in the future this will be possible.
Hi @bega00
I have added it along with the other two Aqara models. If it doesnβt work, tell me to remove it from the driver, I wonβt be able to do anything else
Name Zigbee Window Treatment Mc
Version 2022-12-10T17:14:20.394643227
- id: "LUMI/lumi.curtain.acn002"
deviceLabel: Aqara Curtain Controller
manufacturer: LUMI
model: lumi.curtain.acn002
it doesnβt work for me, Iβll try again
it only goes open doesnβt close and doesnβt stop .
I turn it off from the button
Can you please add:
Data * zigbeeNodeType: ROUTER
- firmwareManufacturerCode: 4476
- firmwareFullVersion: 00010012
- application: 10
- endpointId: 01
- firmwareImageType: 8709
- manufacturer: IKEA of Sweden
- model: TRADFRIbulbE27WSglobeclear806lm
Raw Description 01 0104 010C 01 09 0000 0003 0004 0005 0006 0008 0300 1000 FC57 01 0019
Name Zigbee Light Multifunction Mc
Version 2022-12-11T11:17:51.094822025
- id: "IKEA/TRADFRIbulbE27WSglobeclear806lm"
deviceLabel: IKEA Bulb
deviceProfileName: level-colortemp-2200-4000
