This test version seems to be working well for me, if you had planned to convert this to a non-test driver…
I notice some differences in temperature reporting between this and one of your other drivers (Smartthings Multipurpose). This one seems to be changing only when the “temperature reportable change” is met. The Smartthings Multipurpose seems to be changing when the “temperature report interval” is met. I’m guessing it’s a function of the sensor itself; the ST Multi sensor always seemed to report more frequent and smaller changes than the sensor I had you add to the Zigbee Contact Mc-Test driver.
Hi guys, You mentioned a few issues you were having. I’m trying to add the Lidl 3 outlet as well. How do you control the three outlets or is this a known issue ?
Thanks I was hoping to control the three Individually in ActionTiles/Google/Alexa etc. I guess I can just create a local edge virtual switch to do this.
In the first post of the thread is the list or the link to where the list of devices is in driver. you will see the lidl plug is the first in the list.
the Ikea motion is in the stock smartthings driver
Please I suggest all users search the public github lists for the fingerprints.yml files before asking.
In the next few days it will be impossible to answer everyone in time
Hi @Mariano_Colmenarejo ,
great to be able to change the acceleration Threshold on the smartthings multi sensors. With a low threshold and a couple of them they can be used to detect earthquakes.
Hiya
Ive just added the lidl edge driver to strip light, this was on the sengled ide before.
Any chance you can add this lamp fingerprint which i hope will work as was on the same device handler as the lidl strip
Was wondering if you had considered this - adding the ability to change the tile display to the Smartthings Multipurpose driver to include the temperature display as an option, like you did for vibration?
Added custom settings to configure temperature reports in preferences.
Added an optional profile to be able to use the temperature information in the mosaic instead of the contact information, with the thermostat icon
This version will not be updated automatically as it has new profiles and changes that could affect the performance of the sensor when it is updated.
The Test version, which was in testing, will be renamed Zigbee Contact Mc and will be updated automatically.
The current version 1 will be renamed to Zigbee Contact Mc-(OLD) indicating that there is a new version of the driver.
The new version must be installed in the Hub from the channel and will be updated manually by making a driver change in the device driver menu.
Driver version 2:
│ Name │ Zigbee Contact Mc │
│ Version │ 2022-08-29T09:05:32.008615739 │
│ Name │ SmartThings Multipurpose Sensor Mc │
│ Version │ 2022-08-29T10:35:50.560128324 │
@Sakari , it is possible that the profile in preferences does not match the real profile you see on the device, you just have to put the correct value back.
