(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
What devices are you referring to?
@Mariano_Colmenarejo about this one.
Well, I’m all ears so you can tell me where the sensitivity adjustment
I don’t know how to find it
How can I help you with this “where” ?
Is there some hardware specification?
I mentioned this, but anyone help me.
I am using multi switch driver mc, and in automations tab, in “THEN” dont have on, off options. Just have one option “turn on or turn off”
I’m guessing you are on iOS? If you have access to an Android phone or Chrome book you will be able to
see them.
I have the same issue, see this thread, I have seen other users with the same issue.
Hi @Mariano_Colmenarejo
Please could you add these bulbs to the light driver fingerprints? They’re all currently working with a stock DTH
manufacturer: IKEA of Sweden
model: TRADFRI bulb E27 W opal 1000lm
manufacturer: HZC
model: Dimmer-Switch-ZB3.0
And finally this one - same phsyical model as the first Ikea bulb, but has a different model name.
model: TRADFRI bulb E27 opal 1000lm
Hi @hellodave
are the ikea bulbs color temperature adjust?
Sorry, this device TS0203 is a contact sensor no a motion sensor
No, just dimming.
Oh my gosh! I’ve referred the wrong device, this is the correct:
Hi,
Please can you add this fingerprint for the Yagusmart single gang switch? I installed your zigbee multi switch and child driver and got my Yagusmart 2 gang working perfectly so huge thanks for this.
  • zigbeeNodeType: ROUTER
  • application: 50
  • endpointId: 01
  • manufacturer: _TZ3000_m0btfbt7
  • model: TS0001
  • onOff: catchall
Hi there,
Another one to your endless driver . Please note ZLL profile ID. Zemismart 3 Gangs
Data
application: 09
endpointld: 01
manufacturer: TYZB01_gzhgaaqi
model: TS0003
Raw Description : 01 C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0000
Hi @dotan_shai
Added to this driver version
 Name         Zigbee Multi Switch Mc
 Version      2022-09-28T18:27:16.42588024
 Name         Zigbee Multi Switch and Childs Mc
 Version      2022-09-28T18:27:26.118580542
  - id: "TS0003/TYZB01_gzhgaaqi"
    deviceLabel: TS0003 Switch
    model: TS0003
    deviceProfileName: three-switch
Two gangs also… here are the details:
Data
application: 09
endpointId: 01
manufacturer: _TYZB01_qcgw8qfa
model: TS0002
Raw Description	01 C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0000
 Name         Zigbee Multi Switch and Child Mc
 Version      2022-09-28T19:08:46.052146745
 Version      2022-09-28T19:08:37.744925075
  - id: "TS0002/_TYZB01_qcgw8qfa"
    deviceLabel: TS0002 Switch
    model: TS0002
    deviceProfileName: two-switch
@Dienzora
Install this driver,
uninstall device
open CLI to capture this driver log
reinstall device to see if this device support attribute *CurrentZoneSensitivityLevel
my models don’t support it
 Name         Zigbee Motion Sensor Test
 Version      2022-09-28T20:15:49.524623929
hi
first of all, thank you very much for your work, and your great help.
I checked the drivers, tow gang works great.
But unfortunately three gang is not identified as a edge on st.
I think there was a mistake in the name of the manufacturer.
The correct name is _TYZB01_gzhgaaqi
Missing an underscore at the beginning.
Sorry,
fixed in this driver version
 Version      2022-09-28T20:48:08.627283111
 Version      2022-09-28T20:48:19.117826073
  - id: "TS0003/_TYZB01_gzhgaaqi"
    manufacturer: _TYZB01_gzhgaaqi
    model: TS0003
It works:
2022-09-28T21:32:51.444153031+00:00 TRACE Zigbee Motion Sensor Test  Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-28T21:32:51.450226364+00:00 INFO Zigbee Motion Sensor Test  Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: CurrentZoneSensitivityLevel
2022-09-28T21:32:51.456733031+00:00 PRINT Zigbee Motion Sensor Test  currentZoneSensitivityLevel >>>>>>>>>	2
2022-09-28T21:32:51.461754364+00:00 DEBUG Zigbee Motion Sensor Test  TS0202 Motion Sensor device thread event handled
2022-09-28T21:32:53.545841032+00:00 TRACE Zigbee Motion Sensor Test  Received event with handler zigbee
2022-09-28T21:32:53.569951365+00:00 INFO Zigbee Motion Sensor Test  <ZigbeeDevice: 4eb01caa-12cb-41f0-bbbf-8e2621e8025f [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0xA4, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0xF001, DataType: Uint8, Uint8: 0x00 > > > >
2022-09-28T21:32:53.666036699+00:00 DEBUG Zigbee Motion Sensor Test  TS0202 Motion Sensor device thread event handled
2022-09-28T21:32:53.680260365+00:00 TRACE Zigbee Motion Sensor Test  Received event with handler zigbee
2022-09-28T21:32:53.697587699+00:00 INFO Zigbee Motion Sensor Test  <ZigbeeDevice: 4eb01caa-12cb-41f0-bbbf-8e2621e8025f [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0xA5, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0013, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-09-28T21:32:53.734618699+00:00 TRACE Zigbee Motion Sensor Test  Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-28T21:32:53.801574365+00:00 INFO Zigbee Motion Sensor Test  Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: CurrentZoneSensitivityLevel
2022-09-28T21:32:53.816757699+00:00 PRINT Zigbee Motion Sensor Test  currentZoneSensitivityLevel >>>>>>>>>	2
2022-09-28T21:32:53.821973032+00:00 DEBUG Zigbee Motion Sensor Test  TS0202 Motion Sensor device thread event handled
2022-09-28T21:32:54.358043366+00:00 DEBUG Zigbee Motion Sensor Test  TS0202 Motion Sensor device thread event handled
2022-09-28T21:32:54.882544032+00:00 TRACE Zigbee Motion Sensor Test  Received event with handler zigbee
2022-09-28T21:32:54.892062032+00:00 INFO Zigbee Motion Sensor Test  <ZigbeeDevice: 4eb01caa-12cb-41f0-bbbf-8e2621e8025f [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0x8C, rssi: -65, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x17, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0001, ZclStatus: SUCCESS, DataType: Uint8, ApplicationVersion: 0x46 > > > >
2022-09-28T21:32:54.913264032+00:00 TRACE Zigbee Motion Sensor Test  Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-28T21:32:54.919348699+00:00 INFO Zigbee Motion Sensor Test  Executing ZclClusterAttributeValueHandler: cluster: Basic, attribute: ApplicationVersion
2022-09-28T21:32:54.925353366+00:00 PRINT Zigbee Motion Sensor Test  Firmware >>>>>>>>>	70
2022-09-28T21:32:54.930519366+00:00 DEBUG Zigbee Motion Sensor Test  TS0202 Motion Sensor device thread event handled
2022-09-28T21:32:54.936866366+00:00 TRACE Zigbee Motion Sensor Test  Received event with handler zigbee
2022-09-28T21:32:54.945406699+00:00 INFO Zigbee Motion Sensor Test  <ZigbeeDevice: 4eb01caa-12cb-41f0-bbbf-8e2621e8025f [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x18, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: SUCCESS, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
