(EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
This is the link to specific thread
  • At the end in the fist post is the link to my shared Channel.
  • Install Fibaro Smart Implant Mc driver in your hub from the Channel.
  • Install temperature probes in your device and put it in inclusión mode
  • Add new device from App with search nearby option.
  • New device will appears in the toom were the hub is
  • In app device settings select profile you need (4 temperature probes)
  • Close device and reopen it
  • new profile will appears, if not then close app and clear app cache memory.
Other device users can help you, if you need it
