[Edge Driver Development] [ZWAVE] Calling default handler from custom handler
Hi !
Is there a way to pass the received cmd back to the default handler? I have registered a custom handler for SENSOR_MULTILEVEL as following. The device supports both temperature and illumination. What I need to modify is only the illumination, when I receive the report of Temperature, I would like to leave it to the default handler. But I couldn’t find out how to pass it back to the default handler.
psuedo code below:
local function sensor_multilevel_report_handler(self, device, cmd)
if cmd.args.sensor_type == 3 then
– handle illumination stuff here
else
– WOULD LIKE TO PASS TO THE DEFAULT HANDER HERE…
end
end
[cc.SENSOR_MULTILEVEL] = {
[SensorMultilevel.REPORT] = sensor_multilevel_report_handler
Thanks,
Hi @brandicast
You could do this and it must works
local TemperatureDefaults = require "st.zwave.defaults.temperatureMeasurement"
  -- handle illumination stuff here
  else
  -- WOULD LIKE TO PASS TO THE DEFAULT HANDER HERE…
  TemperatureDefaults.zwave_handlers[cc.SENSOR_MULTILEVEL][SensorMultilevel.REPORT](self, device, cmd)
  end
end
Hi ! Thanks for the tips. May I know where to find the documentation listing the default handlers? I tried to dig out from the official site but couldn’t find any.
And instead of passing the specific TemperatureDefaults, is there a even more general default handler for sensor multilevel report? Assuming the sensor supports more than just 2 capabilities ?
Thanks,
Hi,
In this link you can download firmware lua libraries.
It is essential to be able to develop something
And this is the edge zigbee capabilities defaults documentation
https://developer.smartthings.com/docs/edge-device-drivers/zigbee/defaults.html
Got it ! Thanks for the help !!
I did glance thru the documents just didn’t find out what you mentioned about.
The link you provided last was for ZigBee devices while I am onto ZWave, that’s why I skipped that part. Will give it a try if it works the same as ZigBee API.
Didn’t expect the firmware “lua_libs-api_v6_49X.tar.gz” is in the Release link though. This really helps a lot.
Cheers,
It is the complete documentation, you can also browse the defaults zawe
https://developer.smartthings.com/docs/edge-device-drivers/zwave/defaults.html
Yes, I am aware of that. I read that too. It’s just that unlike zigbee, the document for zwave has not much information about the API. It has limited description as following:
1698898539330
However, I can see it does support the same function from the firmware source code.
Thanks,
