Help requred as I develop Edge Driver for Secure SIR321 switch (Z-Wave)
Hi Everybody,
I am developing an edge driver for my Secure SIR321 Z-Wave switch.
I initially added the fingerprint to my clone of zwave-switch, which somewhat worked.
The SIR321 supports a temperature measurement feature which I intend to control my hot water system.
So I have written a custom edge driver which is working as well as the zwave-switch I based it on. The first problem is the temperature.
Here is my profile:
Blockquote
components:
  • id: main
    capabilities:
    • id: switch
      version: 1
    • id: refresh
      version: 1
      categories:
    • name: Switch
  • id: WaterTemperature
    capabilities:
    • id: temperatureMeasurement
      version: 1
      categories:
      • name: GenericSensor
Here is the display:
Here is the handler:
Blockquote
local function temperature_report_handler(self, device, cmd)
log.info(“temperature_report_handler”)
if (cmd.args.sensor_type == SensorMultilevel.sensor_type.TEMPERATURE)
then
local scale = ‘C’
local sensor_value = cmd.args.sensor_value
if (cmd.args.scale == SensorMultilevel.scale.temperature.FAHRENHEIT) then scale = ‘F’ end
log.info("temperature_report_handler emit_event_for_endpoint cmd.src_channel: ", cmd.src_channel, " sensor_value: ", sensor_value)
device.profile.components[“Temperature”]:emit_event({value = sensor_value, unit = scale})
– log.info(“temperature_report_handler emit_component_event”)
– device:emit_component_event(device.profile.components.WaterTemperature({value = sensor_value, unit = scale}))
– log.info(“temperature_report_handler set_field Temperature, sensor_value: >”, sensor_value, “<”)
– device:set_field(TEMPERATURE, sensor_value, {persist = true})
end
log.info(“temperature_report_handler done”)
end
Here is the logcat output:
2023-05-02T12:42:56.131932789+00:00 TRACE Secure SIR Received event with handler unnamed
2023-05-02T12:42:56.132598247+00:00 INFO Secure SIR <ZwaveDevice: ac678855-741d-4cd6-8ffd-02eba4974a67 [34] (Secure SIR321 Switch)> received Z-Wave command: {args={precision=1, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=18.8, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x22\x00\xBC”, src_channel=0, version=1}
2023-05-02T12:42:56.136993247+00:00 TRACE Secure SIR Found ZwaveDispatcher handler in secure_sir321
2023-05-02T12:42:56.138601747+00:00 INFO Secure SIR temperature_report_handler
2023-05-02T12:42:56.148302122+00:00 INFO Secure SIR temperature_report_handler emit_event_for_endpoint cmd.src_channel: 0 sensor_value: 18.8
2023-05-02T12:42:56.148754872+00:00 ERROR Secure SIR Secure SIR321 Switch thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZwaveDevice: ac678855-741d-4cd6-8ffd-02eba4974a67 [34] (Secure SIR321 Switch)>:
arg1: {args={precision=1, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=18.8, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x22\x00\xBC”, src_channel=0, version=1}
[string “init.lua”]:94: attempt to index a nil value (field ‘Temperature’)
I’m a little rusty but if that’s the attempt to emit the event then it should look something like this:
evt = capabilities.temperatureMeasurement.temperature({value=sensor_value,unit=scale})
device:emit_component_event(device.profile.components['WaterTemperature'],evt)
I have tried various ways of getting the reported temperature to display in the app but my lack of understanding of what I am doing is holding me back (What I would not give for a book on the subject).
The second problem I have is that the SIR321 supports ‘Schedule’ with 30mins, 60mins, and 120mins countdown timer based on button presses, rather than ‘on’ and ‘off’.
So, when I click the button for ‘30 minutes’ I see the following in logcat (duration_byte=30):
Blockquote
2023-05-02T19:15:12.368394678+00:00 TRACE Secure SIR Received event with handler unnamed
2023-05-02T19:15:12.369059803+00:00 INFO Secure SIR <ZwaveDevice: ac678855-741d-4cd6-8ffd-02eba4974a67 [34] (Secure SIR321 Switch)> received Z-Wave command: {args={active_id=3, aid_ro=3, aid_ro_ctl=false, cmds={{cmd_byte=“\x25\x01\xFF”, cmd_length=3}}, duration_byte=30, duration_type=0, recurrence_mode=“REPEAT_EVERY_N_HOURS”, relative=false, reports_to_follow=0, res=false, schedule_id=1, schedule_id_block=0, start_day_of_month=0, start_hour=31, start_minute=63, start_month=0, start_weekday=0, start_year=255, user_identifier=0}, cmd_class=“SCHEDULE”, cmd_id=“COMMAND_REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x00\xFF\x30\x00\x00\x1F\x3F\x00\x1E\x00\x01\x03\x25\x01\xFF”, src_channel=0, version=3}
2023-05-02T19:15:12.370148095+00:00 DEBUG Secure SIR Secure SIR321 Switch device thread event handled
And if I cancel the timer I see the following in logcat (duration_byte=0):
Blockquote
2023-05-02T19:15:25.115809304+00:00 TRACE Secure SIR Received event with handler unnamed
2023-05-02T19:15:25.118302388+00:00 INFO Secure SIR <ZwaveDevice: ac678855-741d-4cd6-8ffd-02eba4974a67 [34] (Secure SIR321 Switch)> received Z-Wave command: {args={active_id=0, aid_ro=0, aid_ro_ctl=false, cmds={}, duration_byte=0, duration_type=0, recurrence_mode=“REPEAT_EVERY_N_HOURS”, relative=false, reports_to_follow=0, res=false, schedule_id=1, schedule_id_block=0, start_day_of_month=0, start_hour=0, start_minute=0, start_month=0, start_weekday=0, start_year=0, user_identifier=0}, cmd_class=“SCHEDULE”, cmd_id=“COMMAND_REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00”, src_channel=0, version=3}
2023-05-02T19:15:25.121886971+00:00 DEBUG Secure SIR Secure SIR321 Switch device thread event handled
As I cannot find anything for ‘SCHEDULE’, my question is: is there such a thing as a fallback handler to handle ‘un handled’ events. I know, sacrilege, but I want to treat the first as ‘on’ and the second as ‘off’. Alas the SIR321 does not report the expiration of the timer, but I guess I could simulate that in my driver.
Suggestions greatly appreciated; please excuse my ignorance; I wish I understood it all better.
Works!!!
Many thanks.
You would need to define your own handler for Schedule:CommandReport. It’s not a frequently used command class so you won’t find it in the default handlers. Below is the ST documentation on it. You should also be able to send Schedule commands to the device using Schedule:CommandSet.
https://developer.smartthings.com/docs/edge-device-drivers/zwave/generated/Schedule.html
Thanks again @philh30 ,
The Secure SIR321 is my third edge driver but my knowledge is very basic so, such a handler would be a bit of a project.
I was a software engineer earlier in my career (Fortran, C, Java) but the only thing that I have found transferrable is debugging and determination.
I would give anything for a book on this.
And I presume the concept of an ‘everything else’ handler would go against the whole concept of Edge or Lua.
Add to your require statements at the top of init.lua (changing version if you know which version of the command class it supports):
local Schedule = (require "st.zwave.CommandClass.Schedule")({version=4,strict=true})
Add the handler. Simply assuming that duration_byte > 0 means on, while 0 means off. You’d have to play with the device to see if that’s always true.
local function schedule_command_report(driver,device,cmd)
  local event
  if cmd.args.duration_byte == 0 then
    event = capabilities.switch.switch.off()
  else
    event = capabilities.switch.switch.on()
  end
  device:emit_event_for_endpoint(cmd.src_channel, event)
end
And add the handler to the driver’s list of zwave handlers.
  zwave_handlers = {
    [cc.SCHEDULE] = {
      [Schedule.COMMAND_REPORT] = schedule_command_report,
you are 2 for 2.
I had a crack at Schedule before but with version=1 and I did not have the duration_byte logic.
Now I need to tidy up, package up, and share.
All the best,
Aidan
