Ok, we are well ‘off piste’ for this thread - but I will try and help.
First thing you need to do is forget about harmony integration for now, let’s just get your alexa & st working together correctly.
First thing you should do is create a virtual device, in ST to trigger your Alexa routine. I suggest using @TAustin 's brilliant driver and instructions to create an alexa virtual switch combo. [ST Edge] vEdge Creator: a virtual device generator for end users - Devices & Integrations / Community Created Device Types - SmartThings Community
The next thing you need to do is configure a routine on the alexa side to control your mount, this routine in alexa should be triggered by the new virtual device you have created.
Now test this, and tweak it until you are happy it is working correctly.
Once working correctly - you can then create a new ST routine that triggers your virtual device whenever you start an activity - using the method I shared on the last post. Choosing either screenshot, depending if you want to trigger on activity ‘starting’ or activity ‘started’
I hope this makes sense
