Does anyone currently have these working that can share with the group? I still have several that I’d like to deploy.
I have it set up and working. What issue(s) are you having?
I just wasn’t sure from reading above the install instructions and which driver to use.
As I said above, mine are using stock drivers; “Zigbee Switch” for the bulb and “Zigbee Button” for the remote. I have the remote controlling not just the Ecobee bulb, but also Osram and Sengled bulbs in the same room.
I have some that look identical that are Linkind branded that will not work with ST, and I know they were rebranded by other companies, too. I wonder if there are different-enough versions, even with the Ecobee brand, that some won’t work?
Reading back, I noticed this
My Ecosmart bulbs are tunable white only, not RGB. Perhaps that’s what makes the difference.
Is there any available driver with “Held” function for this button? Thanks
For those who wants to have the HELD function for button 2 and 3 like me. Here is the link to the driver that I modified from stock driver for Ecosmart 4 button remote. Please note that this remote only supports HELD for button #2 and 3 by OEM. Hence, you even can see the Push and Held option in the Smarthings app for button #1 and 4, you could not assign any tasks for HELD for those buttons.
Hope it helps: Samsung account
