So I have a lamp that is controlled by a GE lighting module, so I’ve found it’s annoying to control the lamp ONLY from the app since there is no button switch in my wall for it. So, I’m looking for an in-wall switch to control it? Does such a thing exist? Also, the lamp is right next to my kitchen lights which I plan to switch over to a GE light switch. So, wondering if there is such a things an in-wall multi switch that can control other z-wave devices (such as my lamp) as well as the built-in lighting fixtures. Almost something light this:
You need to go to the IDE and then go to the smart app section and then click create new smartapp in the top right. Then just put nonsense in for the required fields as this will over write everything anyways and hit create. After that paste the code into the box hit save… then publish>to me. And it will be in your app to install in the “my Apps” section of the smart installer.
you may need to sign up for an IDE account, but thats simple
If it’s not a dimmer, there is already a SmartApp in the convenience section called “The Big Switch” that will do this as well. I use it for my Christmas lights: I have a switch that controls the lights on along my roof line and then I use the Big Switch to also turn on an outdoor module for my yard display.
I don’t personally have one so I can’t say with 100% certainty. The one you linked to may be okay. It’s a zone controller so it is designed to directly control other z-wave devices.
Be careful as there is a nearly identical scene controller version referenced in this thread:
