So I made a smart cat water fountain using the Aeon Labs zwave water sensor. I followed the instructions in this thread …
I modified the Z-wave water sensor DTH as follows but now on actiontiles the tile appears with just a big ? instead of an icon. Is there something I’m missing in the dth? How to I get it to show an icon?
- Copyright 2017
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Cat FountainZ-Wave Water Sensor
- Author: SmartThings
- Date: 2013-03-05
metadata {
definition (name: “Cat Fountain Water Sensor”, namespace: “smartthings”, author: “SmartThings”, ocfDeviceType: “x.com.st.d.sensor.moisture”) {
capability “Water Sensor”
capability “Sensor”
capability “Battery”
capability “Refresh”
fingerprint deviceId: '0xA102', inClusters: '0x30,0x9C,0x60,0x85,0x8E,0x72,0x70,0x86,0x80,0x84,0x7A'}
simulator {
status “low”: “command: 3003, payload: 00”
status “full”: “command: 3003, payload: FF”
tiles(scale: 2) {
standardTile(“water”, “device.water”, width: 6, height: 4) {
state “low”, label: ‘Low’, icon:“st.alarm.water.wet”, backgroundColor:“#e86d13”
state “full”, label: ‘Full’, icon:“st.alarm.water.dry”, backgroundColor:“#00A0DC”
valueTile(“battery”, “device.battery”, inactiveLabel: false, decoration: “flat”, width: 4, height: 2) {
state “battery”, label:‘${currentValue}% battery’, unit:“”
standardTile(“refresh”, “device.refresh”, inactiveLabel: false, decoration: “flat”, width: 2, height: 2) {
state “default”, action: “refresh.refresh”, icon: “st.secondary.refresh”
main "water" details(["water", "battery", "refresh"])}
def result = null
if (description.startsWith(“Err”)) {
result = createEvent(descriptionText:description)
} else {
def cmd = zwave.parse(description, [0x20: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
if (cmd) {
result = zwaveEvent(cmd)
} else {
result = createEvent(value: description, descriptionText: description, isStateChange: false)
return result
def sensorValueEvent(Short value) {
def eventValue = value ? “full” : “low”
createEvent(name: “water”, value: eventValue, descriptionText: “$device.displayName is $eventValue”)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd)
def result =
if (cmd.notificationType == 0x05) {
result << sensorValueEvent(cmd.event <= 2 ? 255 : 0)
} else if (cmd.notificationType == 0x04) {
if (cmd.event <= 0x02) {
result << createEvent(descriptionText: “$device.displayName detected overheat”, isStateChange: true)
} else if (cmd.event <= 0x04) {
result << createEvent(descriptionText: “$device.displayName detected rapid temperature rise”, isStateChange: true)
} else {
result << createEvent(descriptionText: “$device.displayName detected low temperature”, isStateChange: true)
} else if (cmd.notificationType == 0x07) {
if (cmd.event == 0x03) {
result << createEvent(descriptionText: “$device.displayName covering was removed”, isStateChange: true)
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId))
} else if (cmd.notificationType) {
def text = “Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(”, “)}”
result << createEvent(name: “notification$cmd.notificationType”, value: “$cmd.event”, descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? “active” : cmd.v1AlarmLevel ?: “inactive”
result << createEvent(name: “alarm $cmd.v1AlarmType”, value: value, displayed: false)
result
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: “${device.displayName} woke up”, isStateChange: false)]
if (!state.lastbat || (new Date().time) - state.lastbat > 536060*1000) {
result << response(zwave.batteryV1.batteryGet())
} else {
result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: “battery”, unit: “%” ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = “${device.displayName} has a low battery”
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = new Date().time
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
def map = [ displayed: true, value: cmd.scaledSensorValue.toString() ]
switch (cmd.sensorType) {
case 1:
map.name = “temperature”
map.unit = cmd.scale == 1 ? “F” : “C”
break;
case 5:
map.name = “humidity”
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = cmd.scale == 0 ? “%” : “”
break;
createEvent(map)
createEvent(descriptionText: “$device.displayName: $cmd”, displayed: false)
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result =
def msr = String.format(“%04X-%04X-%04X”, cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug “msr: $msr”
updateDataValue(“MSR”, msr)
if (msr == “0086-0002-002D”) { // Aeon Water Sensor needs to have wakeup interval set
result << createEvent(descriptionText: “$device.displayName MSR: $msr”, isStateChange: false)
result
for your Device’s Tiles is because it has an invalid value for the Attribute “
