Double login to IDE to get hubs and devices to show
I’m not sure if this is just the way things are supposed to work but if I want to look at my hub or its devices in the IDE the process usually goes something like this:
  • Go to https://graph.api.smarthings.com/, click the log in link and enter my user details
  • Click on My Hubs, My Devices, My SmartApps, or My Device Handlers because I need to interact with one of those
  • Page loads and tells me I don’t have any Hubs, Devices, etc and that I could add one now
  • Scratch my head for a minute and wonder what happened to my account
  • Remember I need to first click My Locations, then click on my Home location
  • This redirects me to https://graph-na02-useast1.api.smartthings.com/ and I have to log in a second time
  • Tada! Now clicking on My Hubs/Devices/etc has my list of devices and I can do what I needed to do
I’m starting to develop muscle memory to go directly to graph-na02-useast1 when I need to use the IDE but sometimes my browser history suggestion decides to take the long way around (type “graph” hit enter). Is this working as intended? The only reason I could think of for the double login is if the standard use case is people have two different locations on their account that are on two different graph servers, otherwise shouldn’t it immediately redirect (and without a second login) to the correct server?
Somewhere along the line, they have a miscode in their Global Server Load Balancing for the IDE site. No one has taken the effort to correct the load balancer.
Best bet… Just bookmark the https://graph-na02-useast1.api.smartthings.com site.
  • Nate
I have had the same issue since I upgraded from V1 to V2 a week ago
Just find out and then always use the correct URL for your shard…
Well, it’s still a thing. The IDE has never been what I’d call “stable”, but it is literally demanding my UserID and Password between each screen change.
If I move from My Devices to My SmartApps - please login.
Want to open a smartapp? Login.
Edit the SmartApp - Login.
Save the SmartApp - Denied, but hit the back button and login again and I’m good to go… Frustrating.
Marc
Do you have another window open? I have seen something like this if I have smarttiles open and try to log in to the IDE. It keeps logging me out of the IDE and I have to log back in.
if you have smart tiles open in the same browser, you will get that.
Thank you Megan. That certainly would not have been my first suspicion.
I tried today with and without SmartTiles open in another tab and, while I
was being prompted “only” every 5-7 clicks this time in the IDE with the
SmartTiles tab open, in the iDE I am being prompted exactly never with
SmartTiles closed.
Not 100% scientific but good enough for me to say Case Closed!
Marc
