@Danabw
ugh sorry for the confusion - I think I made this more complicated than it needs to be as I tried to retrace my steps. You dont even really need the zebrablinds profile to get the variables.
If you watch this video: https://youtu.be/ybpW4Pn_vdM?t=1m54s
you can set up a profile to get your variables set from your Things. just use thing:ALL and Attribute:ALL to include all subscribed items in sharptools
Then create a task called Notify or something like that using the instructions in my last post. you can associate this with the Thing State profile which got the variables
OK guys, I started from scratch, recorded my actions with a screen recorder and uploaded to Imgur.
I hope this helps anyone following in my footsteps to set up the Thing State profile to get the variables, and then get the AutoCast notification if any Thing changes to âopenâ
Thanks very much - I already had installed Autocast and started the Autocast plugin task in Tasker, so following the steps to complete that (putting in the variables you provided) was actually very easy.
As soon as I can get my dog off my lap Iâm going to go open one of our sliders and see if Google Home will talk to me. smiley:
Thanks very much for the help, your semi-noob state is at the expert level to my complete noob state.
Oops, just saw the post about the screen recording, Iâll check that out. Ignore below for now.
Didnât work for me, unfortunately. Canât really tell where/how itâs failing, unfortunately.
I did confirm the door is registering open with Smartthings. Checked my entries/setup repeatedly, did a full re-setup of the settings, and didnât work.
Whatâs the best way to see where this is falling?
One odd thing, i decided to unsubscribe one door that is in our family room (donât need voice when were right there) and sharp tools wonât unsubscribe from that door, get error 400 from the device list and subscription page on the app, and i tried removing/adding it back to Sharp Tools, but the subscription was still there.
âAdditionally, you can try opening the âSubscriptionsâ pane from the SharpTools left navigation and then manually tap the refresh icon in the action bar to refresh the list of subscriptions. Once youâve refreshed the list of subscriptions, open the Things screen again and check to see if your subscription is setup as expected.â
That fixed the issue I was having with the 400 error.
I used lannouncer on my Nexus 7 with the big talker smartapp which configures the Nexus as a speaker. Next, from the pull down menu on the Nexus, I cast to the Google home. Google home will still respond to commands while being cast to.
For this to work however, the phone has to be present on the same network as your Google Home right? Iâm trying to hook up my door bell sensor to my GH but if the phone isnât present, then the notification wonât work right?
Correct, it needs to be able to cast to your GH on the same network. Since I have a dedicated tablet for my dashboard, it is also used for GH announcements. Many folks have several dedicated tablets around the house so any one of them could be used.
