Grcat
(Ethan)
September 22, 2019, 8:47pm
1
I would like to get an Aeotec siren to sound for 1 second when a Smartthings door break sensor opens. It is easy enough to sound it when a door opens and stop when a door closes but I don’t want it to sound the whole time the door is open. Is there any way to introduce a time parameter?
impee
September 23, 2019, 5:56am
2
Have you had a look at possibly using WebCoRE, i would imagine its very easy to do what you are after with that, as opposed to the Smartthings apps.
Using this Device Handler will allow for short beeps.
I won’t be converting this DTH into an Edge Driver so it will stop working once the Groovy platform is retired.
Aeon Labs Multifunction Siren
(Aeon Labs Siren - Model:ZW080-A17)
This is a new device handler for the Aeon Labs Siren that provides a lot of new functionality.
Alarm Settings
You can choose the sound and volume that the default Alarm should use and an optional Duration.
If the specified Duration is greater than 0, the alarm will automatically turn off after that number of seconds.
[image]
Beep Settings
You can completely customize the default Beep sound and repetition, but it’s limited to a maximum play time of 20 seconds.
Sound #3 is a constant tone so it is the most reliable sound to use for beeps, but it’s still not perfect. When using the repeat functionality…
