Does “Speaker Notify with Sound” support dynamic custom message?
I would like to set it up where my speaker announces which door opens/closes.
Instead of creating a speaker event for each door, would it be possible to pass the device name as a parameter/variable?
Is this something that CoRE supports?
This is fairly straightforward in Core. You want to create a Simple Piston like this:
You can also take a look at BigTalker, it can pass a variable and speak the names of your different devices.
Thanks. I was looking for a way to do it in CoRE. The example you provided is pretty straightforward.
Thanks for the info. I will implement in CoRE, but will keep Big Talker in mind.
Just curious, how did you create the list variable? I couldn’t find it in CoRE
You have to turn on expert mode under settings. Then in the If… menu you can create a variable that is assigned the triggering event’s name.
