Disaster Recovery - If ST Hub dies
All, new to ST and just trying to cover some bases.
I know that there is no Backup/Restore functionality yet in ST Hub. I also not most of the processing is in the cloud. But I assume that 90% of the device associations and state is in the Hub itself. If that is true, will adding a Minimote or other handheld controller as a secondary controller store most of this information ? That way in case you have to replace the hub, you wont lose all your configuration and have to setup the new hub from scatch ?
No. Unfortunately.
Actually, for many users, most of the processing is in the SmartThings Cloud.
Sadly, this hasn’t helped make migration to a replacement Hub any easier.
Have you or anyone you know had to replace a Hub ? How bad is it ?
Many discussions on this; … some old starting points that were convenient (Hub v1 to Hub v2 is essentially the same problem as from a v2 to a replacement v2).
My hub died about a year ago. I have 250+ devices. Wasn’t fun.
