I have a three way setup, one dimmer and one switch now (can’t dim from the second switch). I want to replace it with a zwave switch so I’m getting the 12724 dimmer but what addon switch do I need. The 12723 is much cheaper so I’m confused on what’s better in the GE 45610WB.
So this was a standard 3-4 way switch? If this is the case you need one dimmer switch and an addon switch for each location. I have a dimmer at one end of the downstairs hallway and the addon switch wired as a 3way. I can dim from either switch.
Regarding the 45610: “This auxiliary switch is a component of the GE Z-Wave® lighting control system and is designed to work with the 45607 Dimmer (ZW3002), 45612 Dimmer (ZW3003) and 45609 On/Off Relay Switch (ZW4001).”
