Hi,
I’m looking for a device handler where you can manually and programmatically set values (number and text). To keep this simple, I’ve like to make a simulated device that I can turn on and off and also set another parameter to be either 0, 1, 2, or 3. If possible I’d also like to be able to set an additional parameter to ‘Warm’, ‘Low’, or ‘High’
As well as being able to see and set these values in the device in the ST app, I’d like to be able to read/set these values in WebCoRE.
I am aware that I could use global parameters in WebCoRE but this wouldn’t give me the visibility of the values that I want in the App.
Does anyone have an existing device handler that does something similar please that I could amend for my needs rather than starting from scratch?
Thanks,
Tino
