Device handler for Fibaro heat controller
Unfortunately, it is battery operated, so the tweaker won’t work with it in normal mode. It only works with mains – powered devices. But you can try putting it on its charging cord and see if it will respond to the tweaker then. If it doesn’t, it will require custom code to set the parameters.
If you haven’t used custom code before, it’s pretty straightforward. Basically you will copy the author’s code and paste it into your own account. Here’s the FAQ for that (this is a clickable link):
Device Type Handler
As for device type handlers to try, it self identifies as a generic thermostat, so start by trying one of the Z wave thermostat DTHs and see if that works just to turn the heat on and off.
The problem is that any of the setpoint logic is likely to require custom code, there’s no standard way of doing that so each manufacturer is a little different.
Here’s the manual if anyone wants to look at it. It has the Z wave command sets used as well as the parameter settings you can choose from. :smiling_face_with_sunglasses:
https://manuals.fibaro.com/content/manuals/en/FGT-001/FGT-001-EN-T-v1.0.pdf
