I’ve amended my version of @veonua’s driver to work with QBKG25LM. However, I have had to guess a couple of aspects and may not have it completely correct. Try going to my edge drivers, and log in using your own login information, as for the IDE. From there you should be able to install the driver on your hub. You should then remove the device from your system and reinstall it. It should pick up the new ‘edge’ driver. Let me know how you get on. I may have to ask you to do a couple of experiments to make sure it is correct.
The driver looks completely different, so you should be able to tell easily whether you have correctly installed the edge driver. Sometimes this fails and you get the older groovy driver again. Get back to me if this happens.
This should work whether you’ve installed the CLI or not.
Hi I am totally new to smarthings and github. How do i add your latest DH to my smartthings repository? What do i put under Owner and Name?
Hi @aonghusmor !
I just heard the news that Groovy will be deprecated starting 30 September.
I have a bunch of QBKG24LM . Will your edge driver work with these ones? (2gang
Vlad
It should work. I have included the necessary code, but haven’t actually tried it myself, as I haven’t got that particular switch.
Thanks! Will try it out the day after tomorrow and I will let you know. If it works, you can add it as supported.
Thanks beforehand,
Vlad
