My app found a device it said thing, not sure what it could be. Here is the screenshot. Can someone help? I thought it was an Xiaomai temp/ hum sensor, but not sure.
Where’s the rest of the screenshot? You’re leaving off the most important parts.
Can you compare the raw description to a Xiaomi Temperature Humidity Sensor?
I assume it is that, but even with it showing temp/ hum the description is different. I will wait for 24 hours and see if the battery shows. If it does it is that, as Xiaomi takes 24 hrs sometimes.
