Can I please have the GitHub settings for IDE for future updates?
Nah, safari should pop an error alert - if any error
That part worked for a bit then I changed something and havenât yet gotten to fix it. You need to update ST to latest and then try again, the device list should populate. Attributes still wonât, will get there soon. Add a task, most parameter types should be handled. Need to work on default values and form validation.
How do I delete SE piston, something screwed up and I have a few Pistons in Smartapps on my phone. I tried removing from IDE but it wonât allow removal
Can someone help me delete this Piston from my smartapps?
Tried that it says Piston in use by one or more users.
Tried that also, it is stuck.
Tried that also no luck.
OK I will stand by and wait a while. Maybe Adrian will have an answer. If not I will contact support. I have been complaining for months that my IDE can take 4 to 5 minutes to load and that is if it doesnât time out. It is driving me crazy.
I didnât do any changes! I have been told that support is working on it but like I said it has been months. It all started after they did those network changes about 3 or 4 months ago.
ST and WebCoRE are current, no luck on my Android or PC
Rick
OK, I will contact support now.
Yes, both are current in the IDE.
I canât find the available devices in CoRE, is that in fact in webCoRE or in CoRE? and specifically where. I have looked in every place I can find
Rick
Yes I am aware that CoRE is different than webCoRE.
I was looking for it while editing a Piston which is why I couldnât find it
Now for the full instructions
From the ST app, go to webCoRE then select Setting, then available devices
Still didnât work
On my Android, when I try to select a physical device I get a popup âPhysical devices, cancel or OKâ on my pc I get the input box and nothing more. Tried to enter a letter to two of some physical devices to see if that would help, nothing
Rick
How many devices did you select? On the PC can you logout (this will delete all local storage) and then use the dashboard init url to open it again? You may also open the console in chrome and right click ob the refresh button and choose the empty cache and hard refresh option⌠then watch the âNetworkâ tab for JS requests, you should see one made to ST with load? in it. Select it and look under Preview. Do you see instance? Does it open up to have devices? Are the selected devices listed there?
I am having the same issue where âphysical devicesâ are not showing up, Virtual ones are.
I see the load?callback=angular.callbacks._⌠when I preview that instance:
account
pistons
and then there is location which has hubs, modes, timezone
no devices listed in that call. I even tried loading it up on another computer which would have been clean.
Thank you,
Paul
Yep, found a bug alright. Please try updating ST again, you should get the list of devices.
v0.0.018.20170129 - ALPHA - Fixed a conditions where devices would not be sent over to the UI
yes devices now show but the attribute says ânothing selectedâ so I canât add an attribute or click add at the bottom.
Thatâs fine, never got around to fix those. How about adding an action and some tasks? Most task parameter should be rendered fine though editing back after adding a task may not yet work
Oh man, ask the mobile carrier put it on my tab? lol
