Delay running 'Evening', if I am AWAY
I’d like to run the ‘Evening’ routine at sunset, unless I’m away, in which case I want "Evening’ to not run at sunset, but when I return home (based on mobile presence).
I’m using the classic app. I’m not running CoRE.
In your Evening routine, if you go to the section labeled automatically perform “Evening”, you can find under Advanced Options the choice of Don’t automatically do this if I am in one of these modes. But not sure if it will run after you return and sunset has passed.
" But not sure if it will run after you return and sunset has passed."
Thanks. I did see that I can exclude the Evening sunset trigger based on the mode (set to Away). I assume it won’t trigger if the mode later switches to Home and sunset has passed.
You have two different trigger conditions. Just set up two different routines. :sunglasses:
Routine 1: run routine at sunset only if not in away mode
Routine 2: do whatever you want to have happen when you arrive between sunset and sunrise
That makes sense. Thanks! That’s a simple enough solution.
