So I made my cables for dirt cheap with just a little bit of soldering. I also mounted my tablets for dirt cheap using regular Velcro.
Here’s the part where I got the flat right angle Micro USB Tip:
After disconnecting the Flat Ribbon from the charging receiver, I just needed to find which side was positive and which side was ground:
Since this is for charging only, All I needed was the Vcc and Ground Wire. The flat ribbon cable is coated with plastic so you have to expose the copper.:
I cut the other 2 wires off (White and Green), cut the ribbon cable down the middle (to fully separate for soldering) and tinned both the flat ribbon and Red and Black Wires.
I used 3 pieces of heat shrink tubing. Smaller diameter pieces for the Red Wire (Vcc) and Black Wire (Ground) and one larger diameter to cover the entire connection for a cleaner look.
The rest of the pictures will show the rest:
Considering the tablet already came with the cable, this cost me about $2.00 and about 1 Hour of Labor.
