Ok, so I have a Ct100 Thermostat hooked up to control my Family room fireplace. Currently it is running entirely on batteries as there are only 2 wires coming from the fireplace to the thermostat. Replacing the wires is not a practical option. However…
On the otherside of the thermostat wall is my main house furnace. To run a wire from it to the thermostat would be a piece of cake. However…
The C terminal on the main furnace is already connected to the C terminal on my Nest Thermostat upstairs. So…
My question is: Can I run a second wire from the C terminal (which is already connected to the Nest) on the furnace to the C terminal on the CT100. In otherwords, can the C terminal on the furnace provide enough power for both the Nest and the CT100?
If the above is not a good option, can someone explain how they managed to connected a 24 volltg adapter to thiis thermostat??
No. It might work, but it’d be a Bad Idea. The “C” terminal should attach to a ground that’s part of the same circuit as the +24v going into the thermostat.
Thanks for the info. That makes sense.
So I found a Youtube video that explains how to hook up a 24v adapter. Unfortunately it is somewhat vague on the spec of such adapter. Seems to suggest any 24 ac/dc adapter will do. Am I to assume that This adapter will work??
I dont have a c wire from my heater to my thermostat. I do however have power behind the thermostat in the form of electrical lines, same has what you plug your light switch into. Anyone know of a small transformer I could use that will fit in the box and can be hardwired?
I bought one of these. No issues at all. I plugged it in an outlet in my attic, which is directly above my thermostat. Snaked the wire down behind the wall and plugged it in the thermostat.
I dont have an outlet near by where my thermostat is. I do have electrical wire in a junction box right behind the thermostat so i need a transformer that can be hardwired.
The manual shows 12-24v compatible for the Thermostat c-wire. My thermostat is in the central hallway and that thing would not look pleasing to the eye in plain site lol.
Just a question on this. If I want to install an external adapter is this only working with the CT100 or can I use each thermostat to go that route if I don’t have the C wire?
